20 Most Recent
Whirlpool GR478LXP Electric Kitchen Range Questions & Answers
How do I replace the lower oven heating element?
Hello. Your oven has the hidden bake element. Are you SURE it's the problem--Many things can mimic a bad element. A thermal fuse might have opened, the main oven control board might have a stuck relay that turns on the bake element. TURN OFF THE POWER NOW. To *verify* that the element is indeed bad, you will have to pull the oven out and remove the back cover. Near the bottom you should see the 2 wires connected to the terminals at the end of the element. *Carefully* remove one of the connectors(it doesn't matter which one) and, using a VOM(digital volt meter) set to continuity(it beeps when the leads are shorted together), put each lead on a terminal of the bake element. If the element is good, your meter will beep(there is almost no resistance in the element). If you hear nothing, it means that the element has opened somewhere(just like a broken wire). At this point I highly recommend getting a pro to further troubleshoot the unit. If the element has opened, it can be really tricky to remove and then insert a new one--depending on the model oven you have.
8/16/2015 1:53:24 PM •
Whirlpool...
Answered
on Aug 16, 2015
What does E1 - F1-
F1-E1 - EEPROM Checksum Error - Disconnect power for at least 30 seconds and then reconnect.
Allow at least a minute after power has been restored and if error code reappears, replace control board (clock).
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
10/1/2010 3:45:08 AM •
Whirlpool...
Answered
on Oct 01, 2010
Cooktop burners do not work
sounds like you are only getting 110v instead of 220v check your plug and if it is good you probably got a burnt wire just start looking where the cord hooks to the stove
1/5/2009 12:50:47 PM •
Whirlpool...
Answered
on Jan 05, 2009
Self cleaning oven
Could be a malfunction in the lock mechanism, But if this is a newer oven or first time cleaning, the oven door seal may be holding the door out just far enough to keep the lock mechanism from engaging.
Try pushing in a bit on the top of the door to compress the seal a bit
and then try setting it to lock while holding pressure on the top of
the door. If this works remember you may need to press in on it again
to get it to unlock after it cools.
Also check that the lock lever actually springs out to grab the door and that the hole in the door is aligned properly to receive the lock lever. I would think that you could test this with the oven door open.
12/13/2008 5:09:48 PM •
Whirlpool...
Answered
on Dec 13, 2008
Whirlpool oven door
Hi ShellBrokeIt,
Pivot the hinges outward, and GRop the door by both edges, Feed the slots of the door onto the hinges and slide it on, Close the door and your done.
10/16/2007 4:16:59 AM •
Whirlpool...
Answered
on Oct 16, 2007
Whirlpool gas range diagnostic code E6 46 (cannot find this error code combination anywhere)
E6 46 is a diagnostic code for a Whirlpool gas range. This code indicates that there is a problem with the oven temperature sensor. The sensor measures the temperature inside the oven and sends this information to the control board. If the control board detects a problem with the sensor, it will display the E6 46 error code.
To troubleshoot the problem, you'll want to do the following:
- Check the wiring: Make sure that all of the wires connected to the oven temperature sensor are secure and not damaged.
- Check the sensor: The oven temperature sensor is located in the back of the oven, near the top. Make sure that the sensor is properly seated in its socket and that it is not damaged.
- Check the control board: If the wiring and sensor appear to be in good condition, the control board may be the cause of the problem. You'll want to check the control board for any visible damage or loose connections.
If you are unable to find the problem, I recommend having a qualified repair technician diagnose and fix the issue for you. Electrical issues can be complex and it's important to address them promptly to prevent further damage.
1/8/2023 1:32:12 AM •
Whirlpool...
Answered
on Jan 08, 2023
What is F9 code for whirlpool stove
The F9 error code on a Whirlpool stove typically indicates a problem with the oven temperature sensor. The oven temperature sensor is a device that measures the temperature inside the oven and sends this information to the control board. If the sensor is not functioning properly, it can cause the control board to display the F9 error code.
To troubleshoot the problem, you can try the following steps:
Check the oven temperature sensor: Make sure the sensor is securely connected to the control board and not damaged. You can also check the resistance of the sensor using a multimeter to see if it is within the specified range.
Check the wiring: Make sure all the wiring for the oven temperature sensor is securely connected and not damaged. Check for any frayed or damaged wires, and repair or replace them as needed.
Check the control board: If the oven temperature sensor and wiring are in good condition, the problem may be with the control board. You can try resetting the control board by unplugging the stove and waiting a few minutes before plugging it back in.
If these steps do not resolve the issue, you may need to take the stove to a professional appliance repair shop for further evaluation and repair. They will be able to diagnose the problem and recommend the necessary repairs.
12/24/2022 4:37:31 PM •
Whirlpool...
Answered
on Dec 24, 2022
