20 Most Recent Whirlpool MH6150XMS Microwave Oven Questions & Answers
7answers
Built in Whirlpool Microwave has intermittent power
Check door latch at right position or one of door switch is Brocken.
5/6/2017 10:29:10 PM • Whirlpool... • Answered on May 06, 2017
How do I unlock my microwave
all brands Microwave Display Repair circuit board repair ...
031d26d.namesecurehost.com/mwd/?3e3ea140 Jul 1, 2015 - All brands Microwave Oven Display Repair brand nationwide Sharp Dacor GE G.E. General Electric Samsung Kenmore Frigidaire Whirlpool free help tips. ...Press the "Custom Help" pad and follow the on-screen instructions to unlock the oven....... MH6150XLT-1 MH6150XMB MH6150XMQ MH6150XMS ...
8/4/2015 1:26:11 AM • Whirlpool... • Answered on Aug 04, 2015
2answers
Microwave door has burn spots on the glass of the door...
i have the same problem, there is a brown spot about 3 inch
by 2 inch at the bottom of the glass, I cannot clean it, it looks
like its in between the glass.
9/20/2014 3:30:57 PM • Whirlpool... • Answered on Sep 20, 2014
Emerson mm7 microwave stopped heating
The problem is in the magnetron, or the inverter board, "if 7 years old or less" and possibily the keypad control board.
5/10/2012 8:15:20 PM • Whirlpool... • Answered on May 10, 2012
Microwave only shows dots in clock and does not work
The keypad control board must be replaced.
4/26/2012 1:01:08 PM • Whirlpool... • Answered on Apr 26, 2012
EVERYTHING WORKS ON THE UNIT
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101 ..,.,
11/12/2010 4:21:51 AM • Whirlpool... • Answered on Nov 12, 2010
Does not heat and table won't turn except if
This file should help you.
You can find links to helpful exploded view diagrams and part ordering help here.
I recommend that you bookmark that link to your favorites.Feel free to contact me directly (and please remind me of your full model number from the tag on the unit) for more information & help.
William E. Miller, AS-EET
[email protected]
http://www.microwavedisplay.com
Microwave Oven Control Panel Repair Nationwide
5/4/2010 11:57:36 PM • Whirlpool... • Answered on May 04, 2010
THeood is not getting heated and the turntable is
the unit inside the microwave that heats called the "magnetron" has gone bad or the circuits that power the magnetron and turntable have failed. if its under warranty still, send it back to the manufacturer. if not you can call some repair shops and see how much it would be to service it, but its most likely going to be cheaper to purchace a new microwave since they are relatively cheap these days, and electronics repair people are not cheap. hope this helps
1/15/2010 9:21:19 AM • Whirlpool... • Answered on Jan 15, 2010
The turntable will not rotate and no heating
Thank you for posting the model number. It makes it so much easier.
This is usually caused by either a top bad door switch or a loose door switch mount, which are pretty simple problems to fix.
Even though a door switch clicks, it may still be bad inside.
Door switch or mount trouble is usually caused by slamming the door or by opening the door while it's cooking without hitting the Stop pad first.
There are plastic mounts inside the microwave which hold the door switches and onto which the door latches lock when you close the door.
The screws on these mounts may be loose. If they get too loose, the switches will not be activated properly.
Sometimes it's a broken tab on the switch holder, allowing the switch to rotate just out of position. This tab can be hard to see, since it is under the bottom edge of the switch.
If the switch mount is broken, it's usually more economical and safer to add a dab or two of hot glue to the mount to secure the switch. Let it cool for about 30 minutes before using.
One test that sometimes helps is to gently lift up (and/or push down) on the door or handle as you try to start it. If it works or tries to work, then it's a door switch mount or door alignment issue.
You can find helpful exploded view diagrams and order parts by entering your full model number here.
There should also be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, & testing.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
If you only need a switch, you can order a universal type here for $5 postpaid.
10/11/2009 8:47:23 PM • Whirlpool... • Answered on Oct 11, 2009
MH6150XMT0
You have to separate the door panels (as shown in the attached photo) and then you'll see the previously hidden screws you need to remove.
Or you can watch a YouTube video (not a video I made) that demonstrates how it's done.
You can usually find helpful exploded view diagrams (and order any other needed parts) by entering your full model number here.
When you peel off the old seal tape, it's best to heat it up with a hair dryer and work slowly so it will all come off in one piece and to minimize the amount of adhesive that has to be solved and scrubbed off.
1/29/2009 4:15:30 AM • Whirlpool... • Answered on Jan 29, 2009
Microwave does not heat/cook
Generally, the most common causes of a failure to heat are:
- bad door switches or door switch mounts
- loose connection at the magnetron
- problem or loose connection on the control unit circuit board
- bad magnetron or other high voltage part (such as a shorted diode)
If you or someone you know decide to look into it, we have critical safety information, info on door switch diagnosis and replacement, and disassembly information at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
You can usually find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
There should also be a "mini-manual" hidden inside the unit behind the control panel, which is very helpful when troubleshooting.
We're happy to help and we appreciate your thoughtful rating of our answer.
1/24/2009 3:52:57 AM • Whirlpool... • Answered on Jan 24, 2009
Microwave Not Nuking Anymore
It sounds like the high voltage rectifier has shorted or the magnetron has failed.
There should also be a "mini-manual" (tech sheet) hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, testing, and locating components.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
Here are some links you or someone you know can use (in order given) for test help, but read the safety warnings first:
http://www.gallawa.com/microtech/diode.html (if it is NOT shorted, it's probably fine)
http://www.gallawa.com/microtech/mag_test.html (continuity can be good even though it is bad!)
http://www.gallawa.com/microtech/xformer.html
11/24/2008 2:49:11 PM • Whirlpool... • Answered on Nov 24, 2008
Door-activated power switch is loose and/or has a short
Fixed this problem! The door latches were greasy and sticking in the closed position (i.e., pushed down so not latching and engaging fully when the door was closed) and this created the problems described above. Solution was to squirt some Windex into the latch holes to dissolve the grease. The switches popped back into position (must be spring-loaded) and the door closed and latched properly, allowing the oven to function properly. I swabbed out the hole with a q-tip, let it dry for 20 minutes and all is well.
11/18/2008 5:08:39 PM • Whirlpool... • Answered on Nov 18, 2008
Whirlpool MH6150XMS Microwave Oven Logo
41 questions posted
Top Whirlpool Microwave Ovens Experts
ZJ Limited
ZJ Limited
Are you a Whirlpool Microwave Oven Expert? Answer questions, earn points and help others
View Most Popular
  • Whirlpool Microwave Ovens
Most Popular Question
emerson mm7 microwave stopped heating
  • Microwave Ovens
