20 Most Recent
One For All URC4220 Remote Control Questions & Answers
Need to set my one
Try the following codes: Toshiba 0060, 0154, 0156, 1265 . Turn on the TV manually and then press the TV button on the remote. Press and hold Set until the LED blinks twice; then release the button. Enter the four digit code. The LED should blink twice again. Test if the TV turns off by pressing Power once. If it does, check if the other features of the remote control the TV. If it doesn't, try a different code. You can also manually search for a code by pressing 9-9-1 after holding and releasing Set. Then alternate between pressing Power and TV (for a TV code). Lock in the code when the TV turns off by pressing Set. Check if the remote works for other features.
You can get the manual and codes for the One For All remotes here:
http://www.oneforall.com/support/manual .
If your remote is older than your TV, you may need a new remote. Universal remotes are usually limited to codes for devices released 6 months or more before the remote was programmed.
I hope this helps.
Need code for UCR-3220 to run TV SV2000
URC-3220 One for All Big Easy 3 Universal Remote
I can help you to program your One For All Big Easy URC-3220 Universal Remote to control your TV.
Please review my
Fixya Tip posts for:
- Searching for the proper codes, or
- Downloading the URC-3220 users manual / owners guide. This contains all the codes for the brands of devices your remote can control.
I hope that helps.
Need code
I called one-for-all and got a repair number and then sent the remote to them to have the codes added.
Need codes
Set-up (Programming) procedure is too much to type in here, and is not practical and it will differ brand-to-brand remote controls. If you wish to get more; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. One among it has general set-up codes to check with TVs and other devices are given, in the order of the 'device's brand name list' in alphabetical order. Pull up older posts. Search the sites by type in the brand name to your device in its search box at the top right part of the display window. It will help you to find the document easily.
http://remotesearch.blogspot.com/
http://electro-medical.blogspot.com/
http://electrohelponline.blogspot.com/
Search the site by type in the brand name of your device, in the "Search box at the top right of the Home page display" to see the set-up codes to your device, with different brand remote controls.
Where can I find codes
I need codes
If you wish to get more details; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. Common set-up codes to check with TVs and other devices are given, in the order of the "device's brand name list" in alphabetical order. Pull up older posts.
Codes for remote
Type in the
brand name of your device, in the search box [at the top right] of the display window and the Search will start at once as you type in, and will show you all the related posts. It will make surf easy.
Set up guide for URC-4220
Type in the brand name of your device, in the search box [at the top right] of the display window and the Search will start at once as you type in, and will show you all the related posts. It will make surf easy.
How do I program a one for all remote and how do I get the codes in English?
Type in the brand name of your device, in the search box [at the top right] of the display window, and press enter to get all related posts. It will make surf easy.
What is the code for a sanyo tv and how do I program it
If your TV is older than the URC-4220, the code should be 0154. (The universal remote generally can only control devices that were released about 6 months or more before the remote was programmed.)
To program the remote, turn on the TV manually. Then press the TV button on the remote once. Press and hold Set until the LED blinks twice. Release the Set button at that point. Enter 0154, check if the LED blinks twice again. If the LED blinked properly, point the remote at the TV and press Power. If the TV turns off, this is the correct code. If you take too long between steps, the remote may leave the setting mode. If the LED didn't blink, start over from pressing the TV button on the remote.
The manual for the One-for-All URC-4220 remote is available here:
http://voxrightnow.custhelp.com/app/answers/detail/a_id/11828/~/programming-and-operating-the-oneforall-urc4220-universal-remote-control . Scroll past the directions for using and programming the remote to the link to the Owner's Manual. The list of codes starts at page 36.
I hope this helps.
CIndy Wells
Ineed code for craig dvd player
helllllo.......okaydoky.......anonymous.......go to goggle put in your remote model an your dvd player an they have the codes...........tk.........g.scott
