20 Most Recent Acer Aspire 5100-3357 Notebook Questions & Answers
I have a acer aspire
forward slash button almost always right next to the shift key on the right side of the keyboard
12/24/2018 2:39:08 PM • Acer Aspire... • Answered on Dec 24, 2018
Good morning... I formatted my
You need to wait the setup some more time,VAIO laptop has the same issue,you just need to wait the auto setup.
8/23/2017 10:14:10 AM • Acer Aspire... • Answered on Aug 23, 2017
7answers
ACER ASPIRE 5100 DVD/CD ROM IS NOT DETECTED IN BIOS?
My Aspire 5100 not only looses the cdrom but also the hard drive! It sometimes beeps 3 times.. I'd go into set-up (BIOS) and niether the hard drive or dvd would be listed.. As a last resort, I flashed the motherboard bios with the latest version from Acer and so far the problem hasn't returned. I also set the laptop to hibernate after 30 minutes of non use when both on battery or on ac power. Reason? My problem always started when I left my laptop unattended for some time. When I'd return, the computer would be off.. not asleep or hibernating, but off - even though it was set to never turn off in the power settings in windows. When I'd turn it back on, that is when the hard drive and dvd rom would vanish in the BIOS. So as an added precaution, I set the laptop to always hibernate after 30 minutes.. Like I say, so far so good..
4/30/2016 9:14:36 AM • Acer Aspire... • Answered on Apr 30, 2016
6answers
I NEED ALL THE DRIVERS FOR ACER ASPIRE 5100 - 3357
i need all the drivers for acer aspire
1/27/2015 3:40:58 AM • Acer Aspire... • Answered on Jan 27, 2015
2answers
Windows(Vista) shuts down without notice
Hi KM,
White scribbles, huh? No text or error codes at all?
It might be an overheating issue. That's a common problem with that system. Try putting a couple of coasters or something underneath it and make sure the battery pack and fan areas can breathe. Also, when it shuts down on its own, is it sitting on a couch or somewhere that breathability might be an issue?
Ben
9/17/2013 2:27:02 AM • Acer Aspire... • Answered on Sep 17, 2013
Very, very slow printing
I don't know the make/model of the printer, but I can mention a few possibilities.
1) If your printer is set for PostScript (PS) language, versus PCL , it normally takes longer to print.
2) If this printer is fairly new, check for old Printers installed that are no longer connected to the computer/network. See if there are still print jobs in the queues. A missing printer with jobs still in queue will keep polling the system and eating up processing time.
3) If this printer is a laser printer, it may have to wake-up and warm-up before printing.
9/28/2012 2:46:56 AM • Acer Aspire... • Answered on Sep 28, 2012
2answers
Using battery charger with 3.42A vs 4.74A for lap top
YOu can always use higher amps when required but not lower than required. Voltage should stay the same as original charger - keep it in mind.
8/8/2012 9:55:05 AM • Acer Aspire... • Answered on Aug 08, 2012
My acer aspire 5100-3357 laptop will not turn on what do i do?
Computer does not boot upThe problem maybe the RAM, it is faulty or just needsreseating to make proper electrical contact.Reseat the RAM and then boot up your laptop. If it still does not boot up thenremove the RAM module/s and take them to your friendly computer repair shop andget them to test the RAM for you.
7/15/2012 9:13:16 AM • Acer Aspire... • Answered on Jul 15, 2012
What size/type ac adaptor do I need for my Acer
Volts: 19 - Watts: 65 - Amps: 3.42http://www.amazon.com/Acer-Aspire-5100-3357-Adapter-Replacement/dp/B00337X5I6
10/26/2011 4:34:19 PM • Acer Aspire... • Answered on Oct 26, 2011
The link to the fix
Hi
Post your problem again or adda comment to this post.
Remeber to give as much information as possible (such as which operating system and which remedies you have already tried) to get the fullest reply.
8/27/2011 1:29:49 PM • Acer Aspire... • Answered on Aug 27, 2011
0answers
4answers
It wont boot up and
It sounds like your hard drive crashed. When a hard drive fails many times you can hear it clicking. You will need a replacement drive.
I hope this helps,
Magoo
5/4/2011 12:16:32 PM • Acer Aspire... • Answered on May 04, 2011
Mouse pad doesn't work.
Re install the touch pad driver again and restart.
Hope this helps. Let me know if you need more information Thanks
5/2/2011 2:29:07 PM • Acer Aspire... • Answered on May 02, 2011
2answers
Hello, I cannot connect my ACER
Alright 1) Turn your laptop off, connect the cables to your external monitor such as a t.v, monitor screen, through your apropriate source such as HDMI, VGA, or S-vdieo which ever one you are connecting it to. Turn your external Monitor on, and if it is a t.v make sure it's the the correct input otherwise it won't work. Then Turn your computer on, once your computer is in the Operating system and completly loaded, Then you want to press the FN button + the F5 button to swtich your display from your laptop to your external screen. There is a little Icon that appears on the screen that lets you know that it is switching either it's duplicating, to your external monitor only or back to your laptop screen, your screen may go blank for a second once your made your choise. Then you should be god to go.
2) If it doesnt work, you might want to try loading your computer first and then plugging in the cables and turning your tv on.
3) If that doesn't work, then maybe your FN button is disabled, and you need to enable it in acer windows mobility aplication. If you have question let me know.
2/6/2011 3:18:06 PM • Acer Aspire... • Answered on Feb 06, 2011
Is there a light on
The Acer laptops usually have a light next to the wireless switch from where you turn it on (next to the sound connections on the front). When wireless is on, the yellow light blinks every few seconds. Also in network connections you can see if wireless is connected (in Start, Run type NCPA.cpl and it will bring up the network connections).
12/29/2010 1:06:44 AM • Acer Aspire... • Answered on Dec 29, 2010
I want to replace the dvd drive for acer aspire
A better not complicated solution is an external drive.
Like the:
LG GP08LU10 Optical MediaSlim External Super-Multi DVD Drive You might not know it from looking at this DVD drive's sleek, slim exterior, but it's loaded with capabilities. LG's external CD- and DVD-burner looks great, and works in four unique formats. Super-multi read-and-write lets you select your style for maximum performance, while the USB connection means there's no need for an AC adapter.
If you need more help come back.
Post / thumbs / testimonial are welcome!
12/16/2010 11:18:06 PM • Acer Aspire... • Answered on Dec 16, 2010
VGA problem, can not boot,
Please follow the diagnosis outlined in this article to check whether the backlight lamp or the inverter board are the root cause of the problem or not:
http://www.fixya.com/support/r6430776-troubleshooting_laptop_power_failures
If you connect the external monitor & nothing is displayed on it, then this means that both the backlight lamp & the inverter board are fine. The main indicators in these cases are the sound, and the hard drive LED on the laptop's case. If the laptop sounds just like it always does for a minute or two after being turned on, it means it's going ahead and booting the operating system, but the video processor or part of the motherboard circuit for video output has failed. If the laptop just sits there and beeps when you turn it on, or if you hear the fan but not the hard drive chuckling with its active LED flashing away, it means the laptop isn't getting as far as trying to boot the operating system. While this could be due to any number of hardware problems, the most common and easiest to troubleshoot or repair is RAM failure. If your laptop has two RAM modules installed, try booting with just one and then the other in the primary slot. If your laptop only has one RAM module, you might consider buying one online from a site with a good memory selector, like Crucial.com.
10/29/2010 8:17:55 AM • Acer Aspire... • Answered on Oct 29, 2010
On my laptop, I used to be able to slide the page
HI There,
Please reinstall your touch pad drivers called synaptics on your laptop.
I think that your touch pad drivers are corrupted and gone bad.
Hope this solution fixes your issue.
Please vote me if you think that this solution resolved your issue.
Thanks
Enjoy n Cheers !!!!
10/26/2010 12:36:07 PM • Acer Aspire... • Answered on Oct 26, 2010
3answers
Registry errors
Recover your files while you still can and reinstall Windows.
10/24/2010 8:37:27 AM • Acer Aspire... • Answered on Oct 24, 2010
Can i please have a user manual for the ACER
hope this helps
http://www.mysoft.hu/docs/Acer/AS5732Z.pdf
10/16/2010 8:47:50 AM • Acer Aspire... • Answered on Oct 16, 2010
Acer Aspire 5100-3357 Notebook Logo
104 questions posted
Steve Sweetleaf
Steve Sweetleaf
Grand Canyon Tech
Grand Canyon Tech
View Most Popular
Aspire Acer
  • Aspire Acer
Most Popular Question
using battery charger 3 42a vs 4 74a lap
  • Computers & Internet
