20 Most Recent
Whirlpool GZ7730XGS Stainless Steel Kitchen Hood Questions & Answers
Fan and light not working where is fuse box?
Hi - I have a neff extractor fan and have the same problem. The light and fan have both stopped working. Does anybody know where I can find the fuse as I suspect that this may be the problem too?
2/5/2013 4:17:25 PM •
Whirlpool...
Answered
on Feb 05, 2013
Neff extractor fan not working
I have a similar problem with a Whirlpool oven hood. In my case the kitchen fiitters used a (UK) standard 3-pin plug to power the hood. The plug is fitted into a socket that is placed on top of the cupboards that house the hood.
I have replaced the 3 amp fuse in the plug and now the fan is working.
HOwever, the light isn't working and so I'm assuming that the bulb has blown and that this has caused the fuse to blow as well.
Now my problem is accessing the bulb so that I can replace it.
9/19/2009 5:03:37 PM •
Whirlpool...
Answered
on Sep 19, 2009
Whirlpool gas range diagnostic code E6 46 (cannot find this error code combination anywhere)
E6 46 is a diagnostic code for a Whirlpool gas range. This code indicates that there is a problem with the oven temperature sensor. The sensor measures the temperature inside the oven and sends this information to the control board. If the control board detects a problem with the sensor, it will display the E6 46 error code.
To troubleshoot the problem, you'll want to do the following:
- Check the wiring: Make sure that all of the wires connected to the oven temperature sensor are secure and not damaged.
- Check the sensor: The oven temperature sensor is located in the back of the oven, near the top. Make sure that the sensor is properly seated in its socket and that it is not damaged.
- Check the control board: If the wiring and sensor appear to be in good condition, the control board may be the cause of the problem. You'll want to check the control board for any visible damage or loose connections.
If you are unable to find the problem, I recommend having a qualified repair technician diagnose and fix the issue for you. Electrical issues can be complex and it's important to address them promptly to prevent further damage.
1/8/2023 1:32:12 AM •
Whirlpool...
Answered
on Jan 08, 2023
What is F9 code for whirlpool stove
The F9 error code on a Whirlpool stove typically indicates a problem with the oven temperature sensor. The oven temperature sensor is a device that measures the temperature inside the oven and sends this information to the control board. If the sensor is not functioning properly, it can cause the control board to display the F9 error code.
To troubleshoot the problem, you can try the following steps:
Check the oven temperature sensor: Make sure the sensor is securely connected to the control board and not damaged. You can also check the resistance of the sensor using a multimeter to see if it is within the specified range.
Check the wiring: Make sure all the wiring for the oven temperature sensor is securely connected and not damaged. Check for any frayed or damaged wires, and repair or replace them as needed.
Check the control board: If the oven temperature sensor and wiring are in good condition, the problem may be with the control board. You can try resetting the control board by unplugging the stove and waiting a few minutes before plugging it back in.
If these steps do not resolve the issue, you may need to take the stove to a professional appliance repair shop for further evaluation and repair. They will be able to diagnose the problem and recommend the necessary repairs.
12/24/2022 4:37:31 PM •
Whirlpool...
Answered
on Dec 24, 2022
