20 Most Recent Whirlpool ET9FTKXK Top Freezer Refrigerator Questions & Answers
2answers
The small drain tube in the evaporator compartment
The drain for the water to get away when defrosting is frozen shut...
Checkout this tip to help you..
http://www.fixya.com/support/r3780310-water_running_in_refrigerator_from
heatman101
5/31/2010 3:01:38 PM • Whirlpool... • Answered on May 31, 2010
Refrigerator does not cool properil
There are a few reasons why the refrigerator part will not cool...here are a couple of tips that will help you to figure out why the refrigerantor is not cooling...
Refrigerator2_bing.gif not Cooling or Fridge not Cooling
http://www.fixya.com/support/r3662945-refrigerator_not_cooling_or_fridge_not
How to Defrost Refrigerator Defrost Timer Problem
http://www.fixya.com/support/r3771673-defrost_refrigerator_defrost_timer
heatman101
5/24/2010 3:56:50 AM • Whirlpool... • Answered on May 24, 2010
Water leaking down from freezer
Remove the food and the ice maker from the freezer ( if equiped ) . Remove the rear freezer panel . Using a hair dryer , start in the middle , below the coils , defrosting , until you see the drain hole . Use hot water to help defrost the hole . Once water starts going thru the hole , use a small hose inserted into the hole , and blow thru , to remove any unseen debris in the drain line . Use an ALUMINUM or COPPER , solid wire , 14-16 guage , with the insulation completely off , and insert one end into the drain hole as far as possible without any force . Wrap the other end about 1 1/2 to 2 turns , around the black rod (defrost heater) , above the hole . When refrig goes into defrost , the heat will transfer from the heater , to the wire , keeping the hole from freezing up again .
12/9/2009 1:54:47 AM • Whirlpool... • Answered on Dec 09, 2009
2answers
My Whirlpool et9ftk refrigerator keeps pouring
Your evaporator coils frost up in normal use and every eight hours or so the entire unit shuts down and the defrost heater comes on to melt the frost. This cycle last about 20 minutes. The melted frost drips into a drain pan and through a drain tube to the drain tray under the freezer/refrigerator where it's evaporated by the condenser fan.
Your drain tube may be stopped up with ice at the upper end because it drains too slow because it's stopped up at the lower end in the evaporator pan under the unit at the floor. It can get dust and mold in it. Once you get the ice out at the top a little pressure with a turkey baster will usually clear it out. Flushing it out with hot water and clorox may help.
Make sure it drains quick enough to prevent refreezing. . The drain should be located below the evaporator coils on the lower back of the freezer
11/8/2009 3:34:35 PM • Whirlpool... • Answered on Nov 08, 2009
Freezer drain plug
Self defrosting refrigerators as well as freezers all have a defrost drain system. This drain system can become plugged or frozen causing defrost drain water to back up into the refrigerator or freezer compartment. The water may gather under the crisper drawers on top freezer models. On side by side, bottom or stand alone freezers ice will build up in the freezer at the bottom and eventually leak out the door.
Plugged Defrost Drain - Freezer on Top (Water under the crisper drawers)
At the top of the refrigerator next to the temperature controls there usually is a cup-like part that carries the defrost drain water into a tube and out the back of the refrigerator to a defrost drain pan behind the unit. Pull the cup out of the tube and clean the cup with hot water and soap. If there is no cup, pull the refrigerator out away from the wall, go behind it and disconnect the drain tube to clear it. If the drain tube is not accessible from the back or the drain can not be cleared from there the main back panel in the freezer can be removed to access, thaw and flush out the drain under the cooling coil.
Use a turkey baster to flush HOT water into the tube to clear any obstruction. The water squirted into the tube should end up in the defrost drain pan.
If the tube will not clear with hot water try blowing it out with compressed air.
Put the cup back on and make sure it is all the way on or in the tube.
Plugged Defrost Drain - Side By Side, Bottom-Freezer Refrigerator or Stand Alone Freezer
The defrost drain pan is located at the bottom of the freezer compartment behind the back wall of the freezer. On some models, the pan is accessible without removing the back panel and others are not. After you get to the defrost drain pan use a hair dryer to melt the ice from the pan.
Once the ice is removed use a turkey baster to squirt HOT water into the drain hole to clear the drain.
When the drain is clear you should hear or see the water you are squirting into the hole enter the pan under or behind the refrigerator.
TheRepairGuru ---- www.repairclinic.com
http://www.repairclinic.com/Whirlpool-Refrigerator-Parts
1/26/2009 9:47:36 PM • Whirlpool... • Answered on Jan 26, 2009
Whirlpool wrv986fdem01 no lights
Check the control panel or display on the refrigerator for any error codes or indicators that might suggest a malfunction. Reset the control panel by unplugging the refrigerator for a few minutes and then plugging it back in.
4/3/2024 9:01:44 PM • Whirlpool... • Answered on Apr 03, 2024
Whirlpool refrigerator model WRB322DMBM0 1 with ice maker only. How do I find and change the ice maker filter
The Whirlpool WRB322DMBM01 refrigerator model typically does not have a dedicated water filter for the ice maker. Instead, it relies on an external water filtration system or an in-line water filter that may be installed in the water supply line connected to the refrigerator. Here's how you can check for and change the water filter for your ice maker: 1. **Locate the Water Supply Line**: Trace the water supply line that connects to the back of your refrigerator. The water supply line is usually a flexible plastic or metal tube that runs from the water source (such as a water pipe or faucet) to the refrigerator. 2. **Check for an In-Line Water Filter**: Look along the length of the water supply line for any inline water filters. These filters may be attached to the water line using compression fittings or push-to-connect fittings. They are typically cylindrical or rectangular in shape. 3. **Inspect the Filter**: If you find an in-line water filter, inspect it to determine its type and condition. Some filters have a label indicating the brand and model number, while others may have a date or indicator showing when it was last replaced. 4. **Replace the Filter (if Necessary)**: If the water filter is due for replacement or is visibly dirty or clogged, follow the manufacturer's instructions for replacing it. This typically involves turning off the water supply, disconnecting the filter from the water line, and installing a new filter in its place. 5. **Flush the System**: After installing the new filter, flush the water system to remove any air or debris. Run water through the dispenser or activate the ice maker to purge the system of any trapped air or loose particles. 6. **Monitor Performance**: Monitor the performance of your ice maker and water dispenser to ensure that the new filter is functioning correctly. It may take a few cycles for the water system to fully adjust to the new filter. If you cannot find an in-line water filter connected to your refrigerator's water supply line, it's possible that your refrigerator does not have a built-in water filtration system for the ice maker. In this case, you may need to consider installing an external water filtration system to improve the quality of your ice and water.
4/3/2024 12:33:05 AM • Whirlpool... • Answered on Apr 03, 2024
How to replace freezer light
Delete To replace the LED light in your Whirlpool WRSSDHW08 freezer, follow these steps:
  1. Unplug the refrigerator to ensure safety.
  2. Remove all the items from the freezer to give yourself more room to work.
  3. Locate the light cover inside the freezer. The LED light should be underneath this cover.
  4. Carefully pry the light cover off using a flat-head screwdriver or your fingers. Be gentle to avoid damaging the cover.
  5. Once the light cover is removed, you should see the LED light module. It may be held in place by clips or plugs.
  6. Disconnect the power supply to the LED light. This may involve twisting or pulling the plug from its socket.
  7. Remove the old LED light module from the freezer.
  8. Purchase a replacement LED light module from the Whirlpool website or an appliance parts store. Make sure to get the correct part number for your specific refrigerator model.
  9. Install the new LED light module by connecting it to the power supply and placing it back into its slot in the freezer.
  10. Replace the light cover by snapping it back into place.
  11. Plug the refrigerator back in and test the new LED light.
If you have any trouble replacing the LED light or if you are unsure about any steps, consult the user manual for your Whirlpool refrigerator or contact a professional appliance repair technician for assistance.
3/29/2024 9:30:21 PM • Whirlpool... • Answered on Mar 29, 2024
Why is my whirlpool refrigerator ice maker not working on whirlpool model # WRF535SMBM00. It seems we have no water filter
https://www.appliancepartspros.com/repair-help/whirlpool-refrigerator-wrf535smbm00-repair/wrf535smbm00-ice-maker-not-making-ice.html Whirlpool Refrigerator WRF535SMBM00 Ice maker not making ice Causes of a bad icemaker cycling thermostat can include electrical malfunctions, temperature sensor issues, or wear and tear. Symptoms of a bad icemaker cycling thermostat may include: Inconsistent ice production. The icemaker not cycling properly.
HOW-TO: Whirlpool Refrigerator WRF535SMBM00 Ice maker ...
There is no water filter.
Where is the filter for water for ice maker located on
JustAnswer https://www.justanswer.com > Appliance Repair Jul 23, 2018 - This particular model does not have a filter built into it so that is why you can't find one. If you wanted to add a filter, you can get an in- ...
2/23/2024 6:13:04 AM • Whirlpool... • Answered on Feb 23, 2024
2answers
Whirlpool refrigerator running continuously won't shut off but is not freezing stuff in fridge and freezer is working fine
Sounds like the evaporator fan is not running. Pull the inside of the freezer back off to expose the motor and replace it.
2/21/2024 6:59:51 PM • Whirlpool... • Answered on Feb 21, 2024
Whirlpool freezer defrosting too often causing food to thaw.
If it has a defrost timer, some are adjustable. If not just replace it. https://www.google.com/search?q=Whirlpool+freezer+defrosting+too+often ..
1/7/2024 7:49:35 PM • Whirlpool... • Answered on Jan 07, 2024
Whirlpool ET1MTKXKQ20. Temperature control.
Question edited for clarity, spelling of maker, toss in a load of CAPS. Question moved from Cars and Trucks. Yes they do. https://www.google.com/search?q=whirlpool+et1mtkxkq20 ..
1/1/2024 3:13:20 AM • Whirlpool... • Answered on Jan 01, 2024
Whirlpool ET9FTKXK Top Freezer Refrigerator Logo
Popular Tags
16 questions posted
Top Whirlpool Refrigerators Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
View Most Popular
  • Whirlpool Refrigerators
Most Popular Question
water leaking down from freezer
  • Refrigerators
