20 Most Recent
GE 168947 Toaster Oven with Convection Cooking Questions & Answers
What is the electrical rating
most appliances that have heating elements are rated between 1000 to 2000 watts, which will give you a current rating of between 5 to 10 amps, check at the back of the oven for the ratings. use
the formula P=VI, P(power(w) and V(voltage) and I is the current(amperes). the cord will have a
current rating, go for around 15 amp rating
6/17/2011 8:27:57 PM •
GE 168947...
Answered
on Jun 17, 2011
Dcan I get a part
Here is a GE address where you can check or there is a link to contact the company.
http://www.geappliances.com/service_and_support/
If that doesn't help then here is an address with a list of websites that carry oven parts.
netshoppers.com/search/index.php?phrase=oven+parts&uid=d5d00793c96dccbcaa9b5f3ca3d412cd&kuid=4c4a6ef184c15b7eeffee322a7d94921&src=7s
4/9/2011 6:45:40 PM •
GE 168947...
Answered
on Apr 09, 2011
How to use Rotisserie?
GE has the instruction manual online at: http://www.gehousewares.com/products/countop_oven_rotise_1066410585855.pdf
Make sure you look at the cook times. The manual suggests using a separate timer (I use my regular oven's timer if I'm not cooking anything with that at the time) I've been reading a lot of negative feedback about this product but I love mine and use it regularly.
4/3/2011 2:40:57 PM •
GE 168947...
Answered
on Apr 03, 2011
No broiler heat
its not a diode its a fuse a high temp fuse . there is a number on it with a "c" after it thats the temp it opens ..... you can jump it out with a small bare wire just to test your elements and thermostat . if the thermostat does not cycle this fuse will blow . do not leave it jumped out , this is just for testing . find one on line with the number . and high temp fuse ... good luck
1/5/2011 2:49:26 AM •
GE 168947...
Answered
on Jan 05, 2011
On my GE 169127 Toaster Oven, R2 on the 125301 DC
In my case I found a capacitor on the 9 volt motor control board blown open. It was rated for 250 v but no mfd rating. I called the 877-207-0923 option 4 number. The GE toaster is warrantyed for 2 years. I was able to exchange it for a newer model at the same price today. The new one checks out just dandy.
2/24/2010 12:51:04 AM •
GE 168947...
Answered
on Feb 24, 2010
