20 Most Recent
Krups XP4030 Espresso Machine Questions & Answers
Error Code 9 on a Krups XP7240 Expresso machine
After I changed piston sealing I get the same error 09. It was caused by missing connection to the thermoblock temperature sensor. In my case both connectors for thermocouple were cracked. They are located directly on the body of thermoblock, below two fuses, covered by rubber housing. After I solder them again on the position error 09 disappeared. Unfortunately it is necessary to open at least front panel of the machine. Moreover I tink that there is also important to save polarity of those two cables.
Krups XP4000 Pump Espresso Machine.
If it is brand new you should not be expected to figure it out, take it back to the shop. Any messing about with a brand new appliance can only harm your guarantee, let them figure it out. It sounds like the pump valves are dry or stuck.
Neither water nor steam coming out from never used espresso machine.
From the sound of your You Tube clip the pump is running but it's probably dry and not pumping for some reason. Before I pulled it apart I would try and force some water into the pump. You may find that a piece of garden hose is roughly the right size to engage the tank seal. About a foot of it should be enough, engage the hose, fill it with water, operate the pump like you did in the video and blow as hard as you can into the top of the hose. With sealed lips like you are filling a balloon. If that doesn't work then I think you are doomed and will need to open it up and find where the water stops.
Pump won't stop pumping
It sounds like the electronic PCB has failed and is supplying current to the pump all the time. It's not the sort of repair that a homeowner would be wanting to tackle. They are not made with ease of repair in mind. I would advise getting a quote from an authorised Krups service agent or just binning it.
Need manual
Go to http://www.krups.co.uk/user-instruction Put in 4000 as your search....select download for PDF file.
Dolce gusto
Hi. I work at Nestle on the brand and it sounds like either a fuse issue or a clogged needle. Please call our consumer services number at 1-800-746-3391 for assistance. They are open Mon-Fri 8am to 8pm EST.
Krups XP7240 error OC
OC can mean faulty communication between the 2 boards, disconnect from mains & try again which you have probably already done. There is only 1 cable from the display pcb to the control pcb and that is to the top front of the side pcb.
OC can also mean the distributor is drawing too much power, if that's the issue just replace the distributor.
Machine Fault Error No 06
The error 06 (comes after start up) and machine in auto test - happens because more than one problem. One of the compulory services, rinsing, change water filter, cleaning OR / AND descaling is out of date. Start off with one at a time and do ALL.
Reconfirm it by going into "Product Information" and confirm that the cycles since previous cleaning, descaling and water filter replacement is ZERO.
Your machine will NOT have start up problems any longer
Regards
Error code OA
Where do you get error OA on an XP4030, the machine does not have a display?
No water flow even though descaling
I started the descaling process as according to manual. I tried running water through every 6 hours or so, however it kept coming up dry. I left the water in for a total of 2 days before finally the water managed to come through.
