20 Most Recent Ionic Pro TURBO Air Purifier Questions & Answers
2answers
Why walls around IONIC get so dirty
I was burning candles, which apparently caused my units to carbon up and put soot on the walls _ I will never do that again!
9/23/2021 8:07:03 PM • Ionic Pro TURBO... • Answered on Sep 23, 2021
Where is the ionizer wire?
On the opposite half as the plates. Look for but don't touch the big insulator at the top. The wire run from it to the bottom of the machine. Older ones have a cleaning bead and you must turn the entire machine upside then right side up several times to clean it. Mine had a latch on the back top with a label, " pull up to clean if crackling". I pulled it up and observed a wiper sliding up the big wire inside. I did it up and down several times and that fixed mine.
10/17/2017 1:50:24 AM • Ionic Pro TURBO... • Answered on Oct 17, 2017
2answers
A black film is being found on walls , curtains ,items around it
The black film is caused by mold,which is moisture behind the walls.Clorox with make the black film go away but mold will come back.
6/5/2017 8:31:39 PM • Ionic Pro TURBO... • Answered on Jun 05, 2017
2answers
Ionic pro turbo
You need to clean all the stainless steel contact points inside the unit, not just the blades. Make sure you unplug the unit before doing this.
5/4/2016 9:38:31 AM • Ionic Pro TURBO... • Answered on May 04, 2016
My unit won't turn on after cleaning
Are you sure you did not knock a wire loose that is where I would start
11/6/2015 5:08:44 PM • Ionic Pro TURBO... • Answered on Nov 06, 2015
Why does clean stay on
it has a reset function hold down power 5 sec otherwize check to see if there is any dark spots on the bottom before reinserting. 1st make sure its unplugged then 2nd there should be a copper set up as if putting a 9 volt battery into a fire alarm. there should be two side by side the darkening is where either cleaner was left still dripping or a dust partical probably from the paper towel. caused a static charge. use a Q tip to clean it . and always make sure it is dry if u hear a static sound unplug it is still wet.
6/14/2014 8:06:48 PM • Ionic Pro TURBO... • Answered on Jun 14, 2014
Doesn't put out much air flow? is that normal?
yes its not a fan
6/14/2014 7:50:58 PM • Ionic Pro TURBO... • Answered on Jun 14, 2014
0answers
Ionic Pro TURBO Air Purifier Logo
131 questions posted
Top Ionic Pro Air Purifiers Experts
ADMIN Andrew
ADMIN Andrew
Thomas Perkins
Thomas Perkins
Kardoc
Are you an Ionic Pro Air Purifier Expert? Answer questions, earn points and help others
View Most Popular
  • Ionic Pro Air Purifiers
Most Popular Question
doesnt put out much air flow normal
  • Air Purifiers
