20 Most Recent Krups Burr Coffee Grinder Questions & Answers
manual
I can hear the motor when I push the button but the grinder seems jammed and doesnt spin. How can I fix it?
If you feel secure with dis-assembling the device yourself, and have the tools, you'll probably be able to figure out what the problem is. If not, see if you can call around to places that repair those devices and see if they'll give you a ball-aprk estimate to repair the problem.
11/26/2014 12:29:44 AM • Krups Burr... • Answered on Nov 26, 2014
2answers
GVX2 krups coffee grinder; how to open it?
I have the same issue. You need to take both dials off, then on the bottom, there are 4 tabs on the inside. Seperate the halves and you will see them. Towards the front and halfway back. Pry the halves apart enough to push the top towards the bottom and it slides apart pretty easy. The tricky part now is finding the replacement part. I have super glued my switch and I want to do something to try and repair it further. Maybe epoxy. I called Krups and they can't sell the part to me. I called one of their service centers and they can't sell the part to me. So, if someone knows where to get the part, I am all ears :)
7/10/2014 11:55:40 AM • Krups Burr... • Answered on Jul 10, 2014
3answers
Grinder stalls constantly (motor whirring, but no
As I can see, what happens is that some coffee grains stucks in the way from the upper pot to the grinding wheel. This is not something usual, but possible if coffee grains are too big and are placed across the entry of the mill. Try cleaning more deep with some old toothbrush. Look for a clean and even surface of the duct.
Other cause might be a loosen mill hub/grinding wheel off the motor shaft, which would require dissassemble of the appliance to be repaired.
6/8/2014 12:59:38 AM • Krups Burr... • Answered on Jun 08, 2014
Krups burr coffee grinder - When I push the power
Empty the grinder and see if it will run with no coffee bean in it. Some times debris will get caught in the grinder because it got mixed with the beans from the factory. If it runs your good to go. If not then the mother connection are not solid and it will run off and on at will.
10/17/2013 7:01:12 PM • Krups Burr... • Answered on Oct 17, 2013
0answers
Not spinning
Be the first to answer 9/17/2013 4:49:49 AM • Krups Burr... • Posted on Sep 17, 2013Be the first to answer
0answers
0answers
0answers
It does nothing. I've cleaned
There is no hard reset. Just plug it in, if it works, the contacts were the problem. If it does not work you may try checking the power out of the switch.
2/21/2011 11:15:33 PM • Krups Burr... • Answered on Feb 21, 2011
How to remove blade 0f
On the bottom of the Grinder, You will find several Rectangular holes. With a flat screwdriver push tangs to release bottom. In main shaft, there is a small slot for a flat screw driver. Inseret proper dcrewdriver in slot and turn blades counter clockwise. This should remove blades..
2/20/2011 6:45:16 PM • Krups Burr... • Answered on Feb 20, 2011
2answers
My grinder does not grind at all. For weeks now,
Something must have worn out or gotten loose inside the grinder. I recommend replacing it unless you really feel like tearing into it to find what has worn, loosened, or broken inside. I’m happy to help further over the phone at https://www.6ya.com/expert/jeremy_69f3cc28d95bf514
2/4/2011 8:18:48 AM • Krups Burr... • Answered on Feb 04, 2011
Krups Burr Coffee Grinder Logo
31 questions posted
Top Krups Coffee Makers & Espresso Machines Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Paul Carew
Are you a Krups Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
View Most Popular
Krups Coffee Makers & Espresso...
  • Krups Coffee Makers & Espresso...
Most Popular Question
grinder not grind all weeks now
  • Coffee Makers & Espresso Machines
