20 Most Recent
Amana ALW780QA Questions & Answers
This is for an LW7503W2B
I had the same problem. You need a brake kit. it holds the drum still while in the agitate mode. the centrifical force of the water during that slow spin is causing the water to spill over the top of your drum. easy and cheap fix.
The washer is supposed to be low noise, yet when
not only do you have a loud roar but it's leaking small amounts of water thru the top seal and into the spin brg . top brg and seal will have to be replaced .. the pump may be ok they donot make noise and the belt is normal mantaince . the idler just oil it . . the parts that you stated are in the lower part of the maching and the brg is just under the outer tub . .. and just for your info the pump runs both in spin and agit . so why does it not make noise in the wash ? so back to basic the top brg is only going in the spin and they get noisey whe water get s in them .. we do a lot of these and trust me the top brg is your problem . mm hope this helps ... feed back pls and thanks for ysing fix ya .
Amana ALW780QAW Top load Washer
Hi
Thanks for using FixYa. From what you have described it seems that replacing the bearing should solve the issue however, you can also check the pulley and the brake pads. I dont think they should be bad as if they are bad washer should be making some noise but still would recommend you to check them. Also check this diagram for more information:
Please do
accept the solution if the issue is resolved or else revert for further
assistance.
Thanks
Rylee
Amana washing machine will not spin. it agitates
If your washer does not drain you need to check this parts.
- Inspect the drain hose for kinks
- Test the timer control
- Test the lid switch(some models)
- Inspect the water pump
- Inspect the drive belt(belt drive only)
- Inspect the motor coupler
Water is leaking out of washer; think it is during
The AMANA washer has an outer tub and a water pump. Please check these to make sure you can see where the leak is coming from and replace. Also, if your machine has a dispensing system, check all hoses for THAT system. If upon fill up the out tyub HOLDS WATER and DOES NOT Leak, then the outer tub is okay. Carefullky look at the water pump on drain.
Washing machine will not stop filling
somewhere attatched to the tub/lower water hose is something called a pressure chamber- this will need cleaning out. its identified by a plastic/rubber tube leading from it to a higher switch/unit. in the first instance you can blow some compressed air down the tube to see if that helps. it seems that you may need to do more hot washes. remember isolate machine.
Amana washer. Why is it acting up?
Question edited for clarity, 'Amanda' to 'Amana'.
Question moved to maker category.
It is sensing, and that you have something that needs a 'Delicate' setting, or a 'Woollens' setting. It provides water and very little agitation that might damage or stretch the clothes. Read the manual.
Google
Amana (model) manual
