20 Most Recent Crosman (4032) Questions & Answers
3answers
Have a crossman 1077 airgun but when I put in the
I would send it of to fix, playing with compressed gas is dangerous, sound like a seal my have corroded.
3/24/2023 4:12:58 PM • Crosman (4032) • Answered on Mar 24, 2023
2answers
How to assemble a crosman nightstalker
Do u still have the gun I've got 1 if u still need information
4/22/2019 10:45:03 PM • Crosman (4032) • Answered on Apr 22, 2019
Looking for a repair manual for a crosman 400 air rifle 22 caliper repeater
notify crossman
11/13/2018 8:20:59 PM • Crosman (4032) • Answered on Nov 13, 2018
0answers
Out of order
from a gun shop
11/3/2017 10:21:08 PM • Crosman (4032) • Answered on Nov 03, 2017
My Crosman 1008 Repeat Air pistol leaks all CO2 out
The crosman 1008 does indeed fire pellets! NOT BBs. ONLY pellets.
6/22/2017 2:19:41 AM • Crosman (4032) • Answered on Jun 22, 2017
5answers
Fix crosman airgun
need bolt for crosman silhouette sport pistol looks like a crosman 2300T are they the same? if so where can buy bolt
2/20/2015 10:22:30 AM • Crosman (4032) • Answered on Feb 20, 2015
13answers
Reassembling a crosman 760 pumpmaster airgun
HI, I found something on amazon. here: Crossman Air Guns Model 760 Pumpmaster Owner Manual English spanish... . I hope I have helped. cheers reassembling-crosman-760-pumpmaster-bjo54thclvieudgrgemqnurq-4-0.jpg
12/3/2014 1:34:14 AM • Crosman (4032) • Answered on Dec 03, 2014
6answers
Crosman Powermaster 760 pump bb gun won't hold an air charge
Take a look on amazon Amazon com Crosman Powermaster 760 pump and take a look for replacement. have a nice day
11/24/2014 2:57:32 AM • Crosman (4032) • Answered on Nov 24, 2014
2answers
I have a crosman model
I have the same problem and have dealt with guns for 40 years !I am glad to see that the other folks have some realistic and innovative ideas of how to remedy this problem.I went to Lowe\'s on a "tip" and found some very small \'O\' Rings for $ 0.87 for two and I am experimenting with them. The first try I couldn\'t crank the screw down far enough to even puncture the CO2 Cartidge. Using a larger screwdriver I finally managed to puncture the cartidge, unfortunately it still leaked but waas a much smaller leak. Still experimenting. I am going on-line to locate the Model 380 Schematic diagram which is where I ran int this site. Good luck all !
6/30/2014 3:28:38 PM • Crosman (4032) • Answered on Jun 30, 2014
How to repair a crosman 338 leak
check the link..hope it helps
6/26/2014 5:00:51 PM • Crosman (4032) • Answered on Jun 26, 2014
How should I install a new co2 canister without losing air pressure?
Unless it has a shut off valve, u can not replace it without loosing co2
6/2/2014 9:14:39 PM • Crosman (4032) • Answered on Jun 02, 2014
How do you program a key fob for a 1999 GMC Suburban 2500?
sounds illegal to me
5/8/2014 7:19:25 PM • Crosman (4032) • Answered on May 08, 2014
2answers
Hello, i have a Crosman 760 Pumpmaster Air Rifle,
Sounds like it has a bad o-ring. you can take it apart and replace the o ring for under a dollar. just make sure you look at how it goes back together when you take it apart they are very simple. just make sure the carefully take the right side cover off with the left side of the rifle laying on a table, everything should stay assembled this way so you can look at it. the part you are looking for is in the large chamber that the pump goes into. from the back (the side opposite the pump) remove the spring and the metal piece behind it, then use something the shove the big brass part out of the chamber and the o ring is on the big brass part . take the old o ring to a hardware store to get another one.
1/29/2014 2:09:44 AM • Crosman (4032) • Answered on Jan 29, 2014
New gun - Storm XT Model c1k773932. Never used
where can we order the spring for this gub?
12/14/2013 4:39:36 PM • Crosman (4032) • Answered on Dec 14, 2013
3answers
I have a crosman c11 that leaks gas
Ya your better spending the extra money on something with quality
8/25/2013 8:11:14 PM • Crosman (4032) • Answered on Aug 25, 2013
310 questions posted
Top Crosman Optics Experts
ZJ Limited
ZJ Limited
NOEL
NOEL
Are you a Crosman Optic Expert? Answer questions, earn points and help others
View Most Popular
Crosman Optics
  • Crosman Optics
Most Popular Question
reassembling crosman 760 pumpmaster
  • Optics
