20 Most Recent Nespresso Aeroccino Automatic Milk Frother Questions & Answers
7answers
Burnt Milk at Bottom of Aeroccino
Try this - make a paste from bicarbonate of soda and water and let it
sit in the bottom of the frother for ten minutes or so. Then use a sponge
to clean off the milk stain and rinse and dry thoroughly. To prevent it from
recurring, rinse and dry the inside after each use and don't get the base
of the frother wet.
1/11/2023 8:41:19 PM • Nespresso... • Answered on Jan 11, 2023
4answers
The milk frother has stopped
The solution to rotation issues with the frother have been soved finally by myself after reading all the suggestion. The fix is simple... Your attachments have been magnitised and need to be demagnetized. It works a beauty. Run a magnet around the metal rings. Hint. Never leave them on the the frother when not being used.
1/8/2023 4:14:18 AM • Nespresso... • Answered on Jan 08, 2023
2answers
My Nespresso Aeroccino abruptly stopped working. I
It's the fuse inside. Did it have a burnt residue at the bottom ..if so it's a quick DIY job.
eBay For the replacement fuse!
https://rover.ebay.com/rover/0/0/0?mpre=https%3A%2F%2Fwww.ebay.co.uk%2Fulk%2Fitm%2F292274640385
9/15/2022 10:34:15 PM • Nespresso... • Answered on Sep 15, 2022
Keurig Milk Frother Won't Turn On
Damaged electrical parts might be the reason that your Keurig frother is not working. But your machine is not a waste if some of its parts start malfunctioning. You can buy them from online stores. Read this article for complete fixing guide Why is Keurig frother not working
9/7/2022 6:25:20 PM • Nespresso... • Answered on Sep 07, 2022
Nepresso aeroccino doesn't spin fast enough to froth the milk
The company will tell you to turn upside down for 24 hours to reset. I did this but it did not work. Try turning upside for aeroccino upside down for 24 hr. You do not need to do this to the base. They told me if this does not work, I need to buy a new one. I hope you have better luck. I am on my third one. you may be covered under warranty- call Nepresso soon..they cover them for about 1 year. Good luck
7/16/2021 5:14:09 PM • Nespresso... • Answered on Jul 16, 2021
My nespresso machine won't froth the milk
Brand of milk definitely matters... Here in Canada I used Sealtest 1% when I first used it and the froth was thick light and luxurious. Then one week picked up Neilsen 1% and found it produced absolutely ZERO froth. Back to Sealtest...back to froth. Milk brand matters....but don't know why.
7/16/2021 5:12:49 PM • Nespresso... • Answered on Jul 16, 2021
My Aeroccino frother does not
4 years ago we can not assist you
5/12/2021 9:36:35 PM • Nespresso... • Answered on May 12, 2021
10answers
What does a it mean if the aerocino is flashing its red light?
We had the same thing, and I think it has to do with overheating as well.
After about two goes of frothing hot milk, a little bit of burnt milk residue had formed on the bottom of the jug. I think that "fools" the temperature sensor, and makes it "think" the milk is hot before the frothing time is up (then shuts the machine off, blinking the red light).
As soon as I cleaned the bottom of the jug (had to scrape it with my nails after leaving water in for a while), all systems were "go" again......
My remedy: rinse the jug quickly with cold water after each use, making sure the bottom stays clean!
1/24/2021 8:46:17 PM • Nespresso... • Answered on Jan 24, 2021
We have trouble with the
if you scrape with some hard service material you will have more problems you need to make sure the amount of milk sow is too low plus the stirrer inside the machine is spinning properly?
1/21/2021 4:17:18 PM • Nespresso... • Answered on Jan 21, 2021
3answers
What does a blue light
Means you are not heating your milk, the frothing milk will be cold (for iced drinks) because you have held the button down longer than normal. Usually it takes 5 Seconds for the blue light to go on. try turning it on or pushing the button faster, It should turn on red, for heated and frothed milk.
12/18/2019 7:09:10 AM • Nespresso... • Answered on Dec 18, 2019
4answers
How to increase the temperature of a Nespresso Aeroccino?
Use the bar-style spinner and run it twice.
9/29/2019 4:41:18 AM • Nespresso... • Answered on Sep 29, 2019
3answers
Aeroccino does not heat
Try descaling, if the element is covered with scale it wont produce enough heat and pressure.
The machine is Krups, and therefore should be covered with one year warranty. Call the number listed on the user manual, or find contact from websites below:
Coffee & Espresso Machines - Small Domestic Appliances - Krups
Home - Krups UK
12/5/2018 6:57:38 PM • Nespresso... • Answered on Dec 05, 2018
Red light keeps flashing and milk still cold
See if you can find any help on-line from the supplier or youtube might have something on it.
1/2/2018 11:31:01 AM • Nespresso... • Answered on Jan 02, 2018
0answers
Not frothing
Be the first to answer 12/26/2017 1:38:38 PM • Nespresso... • Posted on Dec 26, 2017Be the first to answer
4answers
How do I make cold froth on my aeroccino for my lattes?
Press the and hold the button for 5sec or longer until the light turns blue. That will get you cold froth.
8/20/2017 4:31:45 PM • Nespresso... • Answered on Aug 20, 2017
2answers
My nespresso aeroccino automatic milk frother is spinning and heating up but not frothing milk
I found that switching to a different milk solved my issue. It worked well with whole milk, but when I used Trader Joe's two percent organic it would not froth after .multiple tries. I borrowed a neighbor's creamer and it worked again.
7/10/2017 11:57:55 AM • Nespresso... • Answered on Jul 10, 2017
I bought a Nespresso citiz
I would change brands. One question do you clean this machine on a regular basis? The nozzle is most likely clogged.
5/11/2017 5:30:52 PM • Nespresso... • Answered on May 11, 2017
Nespresso Aeroccino Automatic Milk Frother Logo
419 questions posted
Top Nespresso Coffee Makers & Espresso Machines Experts
Kolbrun...
Jay Finke
Jay Finke
Sulejman Sulejmani
Sulejman Sulejmani
Are you a Nespresso Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
View Most Popular
Nespresso Coffee Makers & Espresso...
  • Nespresso Coffee Makers & Espresso...
Most Popular Question
aeroccino red light blinks during
  • Coffee Makers & Espresso Machines
