20 Most Recent Jabra BT125 Headset Questions & Answers
I need a earpiece for my jabra bt125
They don't have that specific models' ear gels for sale but they do have some that should be compatible with that headset. Just compare the picture to the ones you had as quite a few are interchangeable.
http://shop.ebay.com/i.html?_trkparms=65%253A12%257C66%253A2%257C39%253A6%257C72%253A4585&rt=nc&_nkw=jabra%20ear%20gels&_dmd=2&_sop=12&_trksid=p3286.c0.m14.l1513&_pgn=1
Thank you,
lee
12/4/2022 12:43:05 PM • Jabra BT125... • Answered on Dec 04, 2022
I have a Eco Sound
This model le-,Bose free sportswear doesn't work
3/18/2019 8:48:58 PM • Jabra BT125... • Answered on Mar 18, 2019
2answers
I AM NOT ABLE TO
Hi,Instructions on how to pair blue tooth device with black berry.
Pair Your Blackberry with a Bluetooth Headset
Turn on Bluetooth headset and Blackberry hand-held.
Enable the Bluetooth radio by going to the options window and clicking on Bluetooth. Click on Enable Bluetooth in that window.
Add your Bluetooth headset to your Blackberry by clicking on Add Device in the Bluetooth window.
Find and select the name of your Bluetooth headset from the list that appears. The Blackberry will search for all Bluetooth devices within range, so other devices might show up on the list.
Click Activate Bluetooth device if you receive a call and the Bluetooth headset does not pick up automatically.
Use your Bluetooth Headset with your Blackberry
Make sure the Bluetooth radio on your Blackberry is turned on before you try to use your Bluetooth headset.
Use the voice-dial feature to call contacts if your headset has that capability. Not all headsets support voice dialing, but more of the newer models do.
Press the on/off button on your headset to end a call or use the end button on the handheld.
Tips & Warnings
Pair your Blackberry with any Bluetooth-enabled device using the same steps as those for connecting a Bluetooth headset.
Remove your Bluetooth headset from the list of paired devices on your Blackberry by selecting and clicking on Delete Device in the Bluetooth window.
Configure your Blackberry to connect to a paired Bluetooth headset without asking for authorization in the Bluetooth Device Properties window. That will allow your headset to automatically reconnect even if you take it out of range temporarily.
Only configure a Bluetooth headset to your Blackberry once. Once you configure the pairing between the two devices, the settings are saved and you do not have to repeat the processes each time you use it.
Turn off the Bluetooth radio on your Blackberry when not in use for security reasons.
Adjust volume on your headset or hand-held to a comfortable level. Excess volume from in-the-ear headsets can cause hearing damage.
Have a nice day .
11/26/2016 3:27:38 AM • Jabra BT125... • Answered on Nov 26, 2016
0answers
Jabra sp700
Be the first to answer 8/16/2014 5:52:26 PM • Jabra BT125... • Posted on Aug 16, 2014Be the first to answer
How to disconnect bluetooth headset from a lost phone
I bought a Jabra Bluetooth headset, It worked fine with my phone(nokia). I lost my phone now. Now i want to use the same headset with my new phone (huawi), but i am unable to connect it to my new phone as the phone is already paired with my previous phone. So please help me with the issue and tell me is there any way i can disconnect the bluetooth headset from my previous phone??
5/27/2014 7:25:19 PM • Jabra BT125... • Answered on May 27, 2014
0answers
0answers
I don't have the pass code that i need to use my
The password for the Jabra BT125 bluetooth headset is '0000' Please come back and tell us if this solved your problem. Thanks.
3/11/2014 8:43:32 PM • Jabra BT125... • Answered on Mar 11, 2014
2answers
Pass key for jabra bt125 headset
It is usually four Zero's, 0000
3/11/2014 8:42:23 PM • Jabra BT125... • Answered on Mar 11, 2014
Hi i need this cell phone battery p-phone fcc-id m9hpm1
i just wanna know how to create an instagram without downloading it and wasting up all my gigga bites for my computer
2/20/2014 12:08:02 AM • Jabra BT125... • Answered on Feb 20, 2014
Tv turns itself on and off the red light blinks 11 times and randomly a bright green light appears around where the picture should be
WHAT IS THE BRAND AND GO TO THEIR WEBSITE AND GET THE SUPPORT
11/11/2013 5:27:32 PM • Jabra BT125... • Answered on Nov 11, 2013
My PS3 can't detect my Bt125
try to hold it really close to the ps3 and make sure that its in pairing mode wen i did it i just held it down for as long as i could till i got a solid blue and then held it close to the ps3 and it worked
4/24/2013 7:16:09 PM • Jabra BT125... • Answered on Apr 24, 2013
0answers
Jabra BT125 Headset Logo
Popular Tags
247 questions posted
Top Jabra Radio Communications Experts
Grand Canyon Tech
Grand Canyon Tech
ExpressFiX
ExpressFiX
ZJ Limited
ZJ Limited
Are you a Jabra Radio Communication Expert? Answer questions, earn points and help others
View Most Popular
  • Jabra Radio Communications
Most Popular Question
buy jabra earhook earloop replacement
  • Radio Communications
