20 Most Recent
Kyocera Copystar CS-1820 Black and White Copier Questions & Answers
ERROR CODE 2101 WHEN TRYING TO SCAN
you have to have a user name and password set up on the computer you are scanning to then you set theat up in the address you set up on the copier.
I am geting an error code of c3100 call for
C3100 Scanner carriage problem
The home position is not correct when
the power is turned on or at the start of
copying using the table.
Poor contact in the
connector terminals.
Check the connection of connector YC4 on
the scanner PWB and the connector on the
scanner home position switch, and the continuity
across the connector terminals. Repair
or replace if necessary.
Defective scanner
PWB.
Replace the scanner PWB and check for
correct operation.
Defective scanner
home position
switch.
Replace the scanner home position switch.
Defective scanner
motor.
Replace the scanner motor.
The mirror frame,
exposure lamp, or
scanner wire is
defective.
Check if the mirror flames and exposure
lamp are on the rail. And check the scanner
wire winds correctly.
took this from a diffirent kyocera copier but it will be the same scanner related code
Kyocera Copier Password (KM-4050)
The factory default password should be 4000. If thast doesn't work you will have to reset or display the admin password in service mode.
To enter service mode hit the ststus button and then type 10871087. Scroll through the menu with the * and # keys. If you make changes in service mode and do not know what you are doing you can cause the copier to permanently fail.
KM2820 ERRO C3100
scanner home position sensor error. has to do with the bright light and mirror assembly that moves back and forth under the glass. DANGER high voltage present
Jam03
Read the manual. Usually unplugging for 1 minute and plugging back in will resolve issue. Check paper track to see if there is any debrea clogging the machine.
What is E31000
Scanner related
=Check if the scanner lock(transportation) is on(should be off).
=Clean inside the scanner.Mirrors and lamp.
How can i remove the error code on my copier: call service C7102
By calling the crevice centre in your manual. sometimes the number is on a card attached to the printer. If you call the centre, tell them what copier you have, what the code is and they also will ask how many copies are made. So write that down before you make the call.
The service centre probably will send a mechanic, to repair the error.
