20 Most Recent Samsung HL-S4266W 42" HDTV Questions & Answers
DLP television
Hello. If you haven't changed the lamp lately, or if you used an aftermarket lamp, that could be the problem. If the lamp is ok, the ballast may have a bad capacitor. A bad capacitor will be puffed up on top. The ballast can be found by following the leads from the lamp. If it's not those, then the color wheel could be defective, and you might be able to hear it making a noise. I hope that helps.
8/10/2016 3:42:51 PM • Samsung... • Answered on Aug 10, 2016
2answers
TV won't stay on. Green & Red light timer-lamp (Green) stand by/temp (red) flash.
Most likely needs a new lamp. Easily done yourself.
7/22/2015 10:04:38 AM • Samsung... • Answered on Jul 22, 2015
Would a cracked screen cause no picture
Would you be able to provide the model number of your TV to provide you with more info? If your TV is a DLP, the lamp would need to be replace to get the picture working again.
5/7/2014 3:47:34 AM • Samsung... • Answered on May 07, 2014
2answers
MY SAMSUNG WORKS FOR ABOUT 10 MINUTES THEN SHUTS
Most likely the temp sensor above the lamp housing. Jump the blue and white wire plugged into it and bypassing sensor and the tv should work.
5/29/2013 7:39:25 PM • Samsung... • Answered on May 29, 2013
My Samsung DLP TV S4266W has snow all over the screen. I've been told I need a new motherboard. Is that true? How much would that cost? Can I buy and install it myself?
Had this problem it is cosd by a befect in a chip call compy and thay will repace for free........no matter how old your set is take care
4/20/2013 10:03:34 PM • Samsung... • Answered on Apr 20, 2013
Samsung 32 "lcd has pwer but wont turn on
To begin someone needs to open and look at the power board for signs of any damaged parts or puffed up filter caps, this is where to begin, if you are not able to do that consider getting it looked at by a tech or a shop.
12/14/2012 4:26:39 AM • Samsung... • Answered on Dec 14, 2012
Samsung HL-S4266W says to Check fan #1. I replaced it and it is running fine, but it still says it. Help!
Either something has to be done to clear that error or the set is detecting something.I have a comment/suggestion here. that error may be misleading you, when you replaced the fan was there a noticeable amount of dust in the set---not like inside a carpet vac but noticeable.I have seen this before in more than one set and brand---first thing we do is roll set outside (I know its getting to be winter) and with the cover off use compressed air and dust the whole set out--don't do it inside as even if set looks fairly dust free it may look like a dust storm when you do this.I have seen many where units were dead or shutting down etc where once the air channels (unit takes in air from front and exhausts it toward the rear) I have a working set with no issues.this is from experience and I hope it may help.SD TECH
12/6/2012 3:09:13 AM • Samsung... • Answered on Dec 06, 2012
My dlp hl-s4266w had developed a 10 " wide vertical darker area than the rest of the sceen
Usually this will be on top or either side and the problem is the optical light engine is damaged from heat----seen about a dozen.
12/4/2012 8:02:09 PM • Samsung... • Answered on Dec 04, 2012
Samsung hlc4266w says replace lamp after lamp replacement
The set may have a lamp timer built in and the owner manual will explain how with the remote resetting that.
9/6/2012 2:40:53 PM • Samsung... • Answered on Sep 06, 2012
Tv keeps shutting off. Currently no soud or picture
The set has a color wheel which may be bad, it often makes a high pitched or fan like sound prior to failure--it can even be a grinding noise.I would with set unplugged remove the lamp cartridge and look where it faces---the color wheel can be seen.What you are looking for is wheel shattered or missing any of the colored segments? If wheel does not turn or runs too slow set will detect this and shut lamp off etc.8_29_2012_5_51_59_pm.jpg
8/29/2012 5:52:08 PM • Samsung... • Answered on Aug 29, 2012
Lamp light flashes then stops. no picture. samsung HLS4266WX/XAA
Was the trouble exactly the same before lamp and wheel were replaced?If lamp comes on for 3 minutes what do you see on the screen?the more you tell me the better I can assist you.
3/17/2012 1:04:40 AM • Samsung... • Answered on Mar 17, 2012
Clcking noise when turning tv on. tv takes about 15 to 20 seconds to come on.
That is a clicking noise came from the relay. This kind of symptoms is an indication of faulty electrolytic capacitor on the power supply board. 11_23_2011_10_56_28_am.jpgInspect the encircled capacitor, most of the faulty electrolytic capacitor bulged at the top, if you can't see any bulged or dome at the top you must have a capacitor checker to determine its condition.Replacing the entire power supply board is another option if you are not comfortable in electronics.
11/23/2011 10:59:35 AM • Samsung... • Answered on Nov 23, 2011
My Lamp won't ignite. At first my TV was just
If the hum came in front of the lamp housing, the fault came from the faulty color wheel. Replace this part and your unit will back to normal operation again.
10/8/2011 1:22:37 AM • Samsung... • Answered on Oct 08, 2011
Samsung tv keeps turning off
I had this problem. It cut off and front panel lights were blinking. Replaced bulb with a phillips OME bulb. Part # is on TV. Cost was about $100.
9/16/2011 2:49:43 PM • Samsung... • Answered on Sep 16, 2011
2answers
Tv comes on for about 10-15 seconds then shuts off
You have a power supply circuit issue.
Possibly a component in the primary side of the power regulating circuit for power on is weak or defective.
You unit will require a tech to look at the power section of your TV.
8/12/2011 2:51:33 AM • Samsung... • Answered on Aug 12, 2011
Tv turns on about 30
Bad lamp again. The lamp life is not dependent on install date but more the amount of use. Ebay for the lamps, a lot of the time you can get them 50% off for refurbs.
7/30/2011 12:43:43 PM • Samsung... • Answered on Jul 30, 2011
Samsung HL-S4266W 42" HDTV Logo
Popular Tags
104 questions posted
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
View Most Popular
HL Samsung
  • HL Samsung
Most Popular Question
dlp television
  • Televison & Video
