20 Most Recent
Sony DVP-FX810 Portable DVD Player Questions & Answers
How do you reset the parental lock passcode on a
Fortunately Sony built in a default password for occasions such as yours. The procedure is laid out on page 45 of your manual. Follow these steps to make use of the built in password:
1) Go to the Parental settings on your menu and choose PASSWORD.
2) input "136900" in the box marked "Old Password".
3) Enter a new password in the "New Password" box. Enter the same password in the "Verify Password" box then press Enter to confirm.
You should now be able to use the new password that you setup above.
Can´t play European dvd´s in my Sony DVPFX810 player!
Hello Selmabjork:
Most DVD players have what u call region codes to play different types of dvd's. Look in your DVD menu settings and select the correct region code where u live. The US region code is 1. So this where I would start.
My question to you is does it play normal dvd's ok. Such as DVD's made in the United States, if so it's set right now for US region.
Also check your user maual for all region codes its usually there.
Happy Viewing....LT
NEED TO HAVE REGION 2 ON MY SONY DVD PLAYER
Sorry, it's not possible. The DVP-FX810 is one of many Sony players where the region coding cannot be hacked without making internal hardware changes. To do so is not cost effective when you can buy perfectly good multi region (or at least hackable players) brand new for £30 including a few Sony models which can be hacked (e.g the excellent DVP5980 with progressive scan, USB input, DivX and HDMI upscaling, still widely available at clearance outlets for under £30).
If you want hackable players avoid Sony and Panasonic unless you have found a model specific hack prior to purchase as many of them have the same limitation.
Sorry there's no fix on this occasion, but I hope that you've found my reply to be of some use. All I ask in return is that you rate my answer.
Does not read disc. I put dvd in, it seems like
Put in an ordinary audio CD and play to notice if the CD is detected. If yes the optical is working, if not there is no laser scanning and the possibility that the laser head can be defective.
Now certain cleaner disks will not be tracked to run for cleaning as it is not read. Hence it will reject. So it is ideal to clean manually the laser head eye using a cotton bud with gentle pressure on the lens eye.
If there is no result then watch if the CD spins or tries to spin. If so the board seems to work unless a test is taken on the main board but the possibility of a defective optical head can be the suspected fault.
If any of the above seems otherwise we must recheck with possibilities of a malfunction of the main processor board
