20 Most Recent Dewalt 18 Volt Compact Drill Kit Questions & Answers
2answers
Dewalt 18V XRP Clutch Slipping
it very economical to repair the drill. replace the transmission.
2/2/2019 11:48:01 AM • Dewalt 18 Volt... • Answered on Feb 02, 2019
Keyless Chuck releases bit when reversed
hi open the chuck all the way and then look down in the centre of the chuck you should see a cross head screw unscrew and the chuck should pull out as this is on a taper system ( note the screw is left hand thread )
1/23/2018 1:15:37 AM • Dewalt 18 Volt... • Answered on Jan 23, 2018
My chuck will not tighten.
it is most likely stripped out and will need to be replaced
8/19/2016 3:46:25 PM • Dewalt 18 Volt... • Answered on Aug 19, 2016
4answers
Removing the dewalt DC925 'rohm' chuck
I simply placed the chuck into a large vise and turned the drill counter clockwise and the chuck spun right off no problem without damaging anything!! It does have some thread lock on the chuck but just use your man strength and its as simple as turning the lid off the pickle jar! Do not waste your time or money with the removal tool...YOU DONT NEED IT!
3/28/2016 4:08:27 PM • Dewalt 18 Volt... • Answered on Mar 28, 2016
Battery won't charge. Light pattern on the charger is " ._._._. Is this battery bad.
What is the residual voltage on your battery, if it is too low, charger will not engage. If the voltage is below the threshold allowed, simply jolt the Nickel Cadmium battery with a car charger to bring it up, then install on charger.
8/14/2015 3:35:44 PM • Dewalt 18 Volt... • Answered on Aug 14, 2015
How to change a keyless chuck dw958
DEWALT DW958 Power Tool Battery ReplacementType: Ni-MHVolt: 18VCapacity: 3000mAhColor: BlackWeight: 1160gDimension: 136.80x85.43x113.00mmhttp://www.drillbattery.com.au/buybattery.php/dewalt_DW958_power+tool+battery.html
5/20/2015 6:40:23 AM • Dewalt 18 Volt... • Answered on May 20, 2015
Replaceing chuck on a Dewalt Dw511 1/2" hammer drill.
Open the chuck jaws and you will see a screw in the center of chuck, it is left hand thread. remove it and use a large bent handle allen wrench putting the short portion in the jaws and tightening. Shift the drill to the low position and have the clutch in the drill only position. place the handle of the wrench at about a 30 degree angle to strike it counterclockwise. put the chuck on a block of wood or workbench and hit it, this might take a couple times but it will come off. Let me know if you still need help
1/4/2015 7:08:32 PM • Dewalt 18 Volt... • Answered on Jan 04, 2015
WHERE CAN I FIND A XR2 18V 2.0 AH DEWALT REPLACEMENT BATTERIES?
This one of your best bets:
8/6/2014 5:21:36 PM • Dewalt 18 Volt... • Answered on Aug 06, 2014
DeWalt DW911 cabinet seperation
go to www.dewaltservicenet.com
shearch by model DW911 loock the break bown
2/20/2014 11:09:25 PM • Dewalt 18 Volt... • Answered on Feb 20, 2014
0answers
0answers
Chuck problem
If it is a keyless chuck, try resting the chuck on a wooden work bench, and with a dead-blow hammer aka: shot hammer, slant-strike the chuck in the unscrew direction.
12/16/2013 6:52:22 PM • Dewalt 18 Volt... • Answered on Dec 16, 2013
Dw997 stopped working, rotates OK, battery fully charged
The speed switch on top may be in between speeds. Try it in a different speed. If not the top switch, the the trigger may be bad. Does reverse work?
12/6/2013 11:48:00 PM • Dewalt 18 Volt... • Answered on Dec 06, 2013
Dewalt 18 Volt Compact Drill Kit Logo
245 questions posted
Top Dewalt Drills Experts
Sean Wright
Sean Wright
Are you a Dewalt Drill Expert? Answer questions, earn points and help others
View Most Popular
Dewalt Drills
  • Dewalt Drills
Most Popular Question
dw997 stopped working rotates ok
  • Drills
