20 Most Recent
Durabrand DWT1304 13" TV Questions & Answers
Channel set on a DWT1304 tv, I need it to go to channel 3, it goes to channel 4
Do a factory reset to this set, and then check. There are two methods to reset TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight is better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; check the site linked here. Pull up older posts.
Service mode entry, adjust and exit procedure to many popular brand TVs are given. Never forget to exit the service mode, after all adjustments have been done.
8/28/2016 1:16:15 AM •
Durabrand...
Answered
on Aug 28, 2016
Lost my remote
Sometimes you can change the input by just clicking the channel button up >>> after the highest tv channel it'll go to Input 1, Input 2, etc. That's worked on one of my tv's but not all of them so it might work for you, too. Next suggestion would be to buy yourself a couple of universal remotes & keep them in a junk drawer for when you need one! We've found this PRICELESS!!! (Buy a couple when they're on sale & store them for those days when the remote was devoured by that oh-so-sneaky sofa!)
2/8/2016 6:11:58 PM •
Durabrand...
Answered
on Feb 08, 2016
Accidently changed something and not able to get antenna tv now - do not ahve cable here at work
I am unable to see at a glance how to correct this but it is between its menu, channel and volume buttons to alter the settings it may be worth to run through the re-tune sequence below?
To preset a channel or to change a preset channel, follow the procedure below.
1) Press the POWER button to turn on the TV.
2) Press the MENU button so that the menu display appears
on the TV screen.
3) Press the CH(annel) ? or ? button to point to "CHANNEL SET".
Then, press the VOL(ume) ? button.
4) Press the CH(annel) ? or ? button to point to "AUTO PRESET CH".
The tuner scans and memorizes all active channels in your area.
? The TV distinguishes between standard TV channels and cable channels.
? When AUTO PRESET CH action is completed, the lowest memorized channel reappears on the
screen.
? When you press the CH(annel) ? or ? button after selecting "AUTO PRESET CH", the tuner
will stop at the memorized channels only.
? The TV may recognize TV channels to be CATV channels by the receiving conditions. In this
case, try AUTO PRESET CH action again in the fine receiving conditions.
? When AUTO PRESET CH is activated where there is no TV signal input,"NO TV SIGNALS"
will appear on the display after the completion of channel scanning.
[ADD/DELETE FUNCTION]
1) Press the MENU button so that the menu display appears on the TV screen.
2) Press the CH(annel) ? or ? button to point to "CHANNEL SET".
3) Press the VOL(ume) ? button so that "ADD/DELETE" is selected.
4) Use the CH(annel) ? or ? button to select the
channel you wish to put into memory or to erase from memory.
Note: The menu will disappear in about 10 seconds.
Perform "ADD/DELETE" function while this display appears on the
screen.
? Press the VOL(ume) ? or ? button to light up the channel number
in LIGHT BLUE if you wish to add the channel into memory.
in LIGHT RED if you wish to erase the channel from memory.
5) Press the MENU button to exit the menu.
Hope this helps.
10/10/2015 3:30:41 AM •
Durabrand...
Answered
on Oct 10, 2015
How do i recieve uhf channels
If your television is fitted with a UHF tuner it should just be that you need to re-tune your set. This is often the case between seasons. If it is not fitted with one, then you need to buy and install a digital set top box to receive all stations, (Analogue, UHF and digital) in your area.
10/14/2014 2:42:14 PM •
Durabrand...
Answered
on Oct 14, 2014
Duranrand Tv
You need the original remote controller to be able to switch input modes.Universal ones usually don't work. If you don't have the original remote and can't find it ever or if it is too expensive you can buy an rf modulator ( very cheap) and connect your dvd player, game console etc) to the modulator then connect the modulator to your antenna with a coax cable. This worked for me. It placed the connection to channel 4 and other cable channels are still working,
You can buy the RF Modulator from: http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&rd=1&item=170273581556
8/11/2014 10:27:47 AM •
Durabrand...
Answered
on Aug 11, 2014
