20 Most Recent Sanyo HT27546 TV Questions & Answers
I have a Sanyo vizon
Reorient your antenna and put as high as possible. You might also consider getting a signal amplifier for it.
9/7/2017 10:40:34 AM • Sanyo HT27546 TV • Answered on Sep 07, 2017
I have my cable coax connected to the UHF, VHF,
You need to put a compatible cable decoder box between the cable and TV as the sanyo will only decode analogue cable signals via the catv UHF vhf input the digital antenna in is for digital air broadcasting signals only
7/25/2017 3:41:01 PM • Sanyo HT27546 TV • Answered on Jul 25, 2017
Distorted picture and color problems
If when you watch tv it is fine then your problem is not with the tv. First eliminate the possibilities. plug your DVD into another tv and see if the problem persists. If it does it is your DVD. Next, replace cables. Not likely but the jack on the tv could be bad. Check those things and let me know if you have any other questions. There is more that can be checked before getting crazy.
1/11/2014 10:48:55 PM • Sanyo HT27546 TV • Answered on Jan 11, 2014
0answers
Sanyo tv model ht27546
our year old tv plays wonderful then it will turn green an the after a while it will go back to normal .we were told that some stores put a chip in it so that after about a yr it will do that.the picture is great but then the screen turns green,what can we do to fix that?
12/4/2012 12:12:28 PM • Sanyo HT27546 TV • Answered on Dec 04, 2012
The power button broke need to find a replacement. Where can I find repair parts?
Contact the nearest authorised service center for Sanyo.
5/10/2012 10:23:03 AM • Sanyo HT27546 TV • Answered on May 10, 2012
I have a sanyo tv
Hi Henry,
You didn't mention the brand and model of your remote, anyway you may try the universal code below.
SHARP Codes: 004/ 009/ 079/ 095/ 111/ 112/ 114/ 122/ 123/ 124/ 173
Enter 3-digit code at a time.
Hope I helped you.
Have a nice day!
Thanks for using Fixya.
2/24/2011 4:33:34 AM • Sanyo HT27546 TV • Answered on Feb 24, 2011
How do i get to menu without remote
it appears there is no menu button for this tv but you can buy a replacement remote for this model , here is the link
http://www.thefind.com/search?query=Sanyo+HT27546+TV
9/26/2010 11:23:01 PM • Sanyo HT27546 TV • Answered on Sep 26, 2010
Lost remote. closed captions on. is there any way
here is the manual
http://www.retrevo.com/search/v2/jsp/downloadPage.jsp?doc=7eb82b548ada65fb3ed52985326223f4&modelid=311865&q=Sanyo+HT27546
go to the section
" MENU MAP "
on page 14
Fosg2000, Rate me please
4/26/2010 2:07:29 PM • Sanyo HT27546 TV • Answered on Apr 26, 2010
Remote control will not decrease volume. it will
Check to see if it will decrease on the TV itself,install fresh batteries, mash the down button on the remote applying a little pressure, button may be stuck. hope this helps..
3/25/2010 8:00:29 PM • Sanyo HT27546 TV • Answered on Mar 25, 2010
The digital tuner seems to work intermitantly
Replace it.
7/12/2009 7:35:08 PM • Sanyo HT27546 TV • Answered on Jul 12, 2009
Can get power but no picture or sound
Is your Tv Raster is there? if not probably your Horizontal section of tv not functioning. Check the B+ first.
6/1/2009 1:41:57 AM • Sanyo HT27546 TV • Answered on Jun 01, 2009
I have this v it
tv signals are still in analog.....digital has not taken effect yet.
3/1/2009 11:07:15 PM • Sanyo HT27546 TV • Answered on Mar 01, 2009
AV switch
hiya
the av on tv's are normally done automatically on detection of a video feed via the scart sockets. if yours does not have this feature then on ur remote u shud find a button that says tv/av
rik
2/24/2009 11:47:56 PM • Sanyo HT27546 TV • Answered on Feb 24, 2009
Do I need converter for Sanyo DS24424A manufactured in 2005.
hiya
what you may need is a freeview box unless ur tv has in built digital
rik
2/24/2009 11:43:47 PM • Sanyo HT27546 TV • Answered on Feb 24, 2009
Sanyo HT27546 TV Logo
32 questions posted
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Sanyo Televison & Video
Most Popular Question
sanyo vizon
  • Televison & Video
