20 Most Recent GE Nautilus 24" Built-in Dishwasher Questions & Answers
Water leak through garbage disposal
I'm pretty sure the "air hose" is the drain hose from the dishwasher and is supposed to empty in the garbage disposal. Garbage disposals are made for this optional hook up with a plug you have to knock out and remove from the inside of the disposal. If you run the dishwater with the hose not connected to disposal it has to be going somewhere!
3/2/2019 11:44:54 PM • GE Nautilus 24"... • Answered on Mar 02, 2019
Always little crumbs in glasses on top rack
Cleaning screens is part of regular use of the dishwasher and how to should be included in the user guide. If you don't have one look for it on the internet by searching for user manual for your model number which can be usually found on the side of the door or frame where the door closes. Good luck.
2/13/2018 1:11:32 AM • GE Nautilus 24"... • Answered on Feb 13, 2018
The screw that was holding the dishwasher dropped
If the screw is left in there it will eventually get to the pump impeller and severely damage it Try to get it out
1/9/2018 12:38:05 PM • GE Nautilus 24"... • Answered on Jan 09, 2018
0answers
Our 5 year old dishwasher is not running properly.
It sounds like it is a board issue. The board tells the washer what to do. What brand do you have?
7/6/2017 12:45:45 AM • GE Nautilus 24"... • Answered on Jul 06, 2017
My model # is:GSD2200G00BB. It is 12 years old.
The best thing to do here cost wise is to replace the unit.
6/29/2017 2:21:46 AM • GE Nautilus 24"... • Answered on Jun 29, 2017
Dishwasher won't drain all the way
A dishwasher will never drain all the way. It is designed to hold water as to not let the pump run dry and keeps the seals preserved.
6/3/2017 5:09:50 AM • GE Nautilus 24"... • Answered on Jun 03, 2017
Dishwasher will not fill with water
the fill solonoid , located within inches of water hook up fitting has a bad connection on the coil or has failed.
4/25/2016 6:28:57 AM • GE Nautilus 24"... • Answered on Apr 25, 2016
2answers
No water goes into dishwasher.
I've experienced the same thing. Try very slowly rotating timer dial, click by click, until the water starts. Sometimes 3 or 4 clicks will start water. (You're advancing the clock.) Usually water starts in before the dial points to, "Short Wash." If this doesn't work, advance the dial to, "Off," unlock and open the door, reset, close, the soap dispenser, close and lock the door, and slowly advance the dial until the unit starts. I think this problem is a clock to pump issue and what I've described does a reset of the system. This happens to me once or twice per month. Poor engineering but still better than buying a new machine...at least 'till now.
2/7/2016 3:46:54 AM • GE Nautilus 24"... • Answered on Feb 07, 2016
GE Nautilus 24" Built-in Dishwasher Logo
887 questions posted
Top GE Dishwashers Experts
Mike Cairns
Mike Cairns
Grand Canyon Tech
Grand Canyon Tech
Are you a GE Dishwasher Expert? Answer questions, earn points and help others
View Most Popular
GE Dishwashers
  • GE Dishwashers
Most Popular Question
gsd4200 will not clean dishes all
  • Dishwashers
