20 Most Recent
HP Officejet 4315v All-In-One InkJet Printer Questions & Answers
Do you know how to
Try below resets
Power Drain:
- Turn OFF the printer, disconnect the power cable from backside of the printer and from wall outlet.
- Press and hold the Power button for 60 seconds.
- Connect the cable and turn ON the printer.
Partial Reset
- Remove the power cable from back side of the printer while its ON.
- Press and hold "#" and "3" button, while holding them both insert the power cable and release the button after 10 seconds.
- If printer turns OFF, press power button to turn it ON.
Semi-Full reset
- Remove the ink cartridges.
- Press and hold "#" and "6" button, while holding them both insert the power cable and release the button after 10 seconds.
- Insert the ink cartridges.
NVM Reset
- Press and hold "OK" and "Cancel" button, while holding them both insert the power cable and release the button after 10 seconds.
Regards
Riztech
Printing 4x6 on hp 5610
I just wanted to ask you a question, I have a HP Color LaserJet CP2025 printer, and i couldn't find the setting of the Photo printing or ( Media and Quality) Could you help please!https://dltutuapp.com/https://9apps.ooo/https://showbox.run/
HP Officejet 4315v All-in-One turns off
IT SOUND LIKE IT SETUP TO ANSWER A FAX MACHINE MODE.
I WOULD GO ONLINE AND TYPE THE FOLLOWING INFORMATION :
HP OFFICEJET 4315V TURNS OFF AUTOMATICALLY
ENTER
SEE IF ANYONE ELSE HAD THIS PROBLEM AND MAYBE HOW TO SOLVE IT OR IF IT IS A RECALL OR MFG ERROR.
Hp officejet 6500 all in one
The scanner has a separate driver. Go to Device Manager and click "Imaging Devices." Is the scanner there? If yes, try to update driver. If it's not there, right click and select "scan for hardware changes." Plug and play should see the scanner and install it. If not, go to control panel, hardware, add device. Keep the disk in the machine, as you know it has the drivers on it. If there is a newer driver online, you can update later.
NO POWER UP HP PRINTER 4315
Is it getting power? Is the cord ok? Is the adapter that came with printer ok?
If power is definitely reaching the printer and it is dead then you have to consider a replacement since repair is not cost effective. And if you have spare ink for unit you might just want to consider replacing it with identical unit since HP screws you with printer cartridges and respective cost.
How can I reset my printer
After you have cleared the jam, make sure you
press the control panel back into place. You may also need to remove any jammed
paper from the rear access door or from inside the device.
My printer keeps saying its
my printer keeps saying its offline and will not print i did what it said and now it says its online again but still wont print .....anyway to solv this ....thanks.....i have a hp officejet 4315v all in one
nel pls help
Why is it just the "scan" not working
If you moved up on operating system the printer wasn't able to follow. Don't worry windows can run the printer and scan part without hp software. Just make sure you have the driver for that operating system. If one is not available try using the one for the operating system it was on before, or try updating. To update go to control panel/device manager look for a yellow exclamation mark. It may be your scanner. Right click and choose update driver allow it to search online. Then in control panel/devices and printers right click your printer and choose scan
Am not receiving fax but able to send fax
Firstly have you connected the same phone line with your phone as well?? or its a dedicated phone line??? changed the settings on the printer1. press setup (the wrench icon) >>> then go to fax settings>> basic fax>> ecm - turn it off2. press setup (the wrench icon) >>> then go to fax settings>> basic fax>> auto ans: onsimilary rings to ans :6 if your TAM is set to four rings or else if you are using a dedicated phone line then your rings to ans should be : 2 fax speed medium...then try and check if that works....
