20 Most Recent
Sony Cyber-shot DSC-W35 Digital Camera Questions & Answers
I want to change the
Press MENU to display the menu. Press cursor-right, select Settings (toolbox icon), press cursor-right again. Use the cursor keys to select the "A" icon and press the button at the center of the cursor pad.
Memory stick
go to a studio and ask them to retrive - they have a software to retrive even deleted pictures
Then look at the capacity of the memory stick and take pictures
Sukesh
When I turn on sony cyber-shot camera I get a
Problem with the Sony Cyber-shot DSC-W35 Digital Camera
when I turn on sony cyber-shot camera I get a screen
display that states "access". The lens keeps going in and out and then
it states,"turn the power off and on again" What's wrong??
Free download cyer shot ddsc-w35
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as the free
Picasa.
I lost my installer of
You don't need to install anything.The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as
Picasa.
How do I change the settings to take a 300 DPI
DPI (dots per inch) is an output specification and is irrelevant as far as the camera is concerned. The camera has to put some number in there, and it uses 72 since that's the value usually often for computer monitors. The only time it really means anything is when printing the picture. As such, you can change it in whatever program you use to print the picture.
No matter what the set resolution all pictures
PPI (points per inch) is an output specification and is irrelevant as far as the camera is concerned. The camera has to put some number in there, and it uses 72 since that's the value usually often for computer monitors. The only time it really means anything is when printing the picture.
When i connect the camera through the usb a box
Try NOT connecting your camera to your computer.The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as
Picasa.
DSC-W35 drivers/software download from internet
You don't need any drivers or software.The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries. Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or, despite what I said first, you can use any photo cataloging program such as
Picasa.
