20 Most Recent
Sony Handycam HDR-SR1 HD Camcorder Questions & Answers
What is the best way to convert MTS file to MOV file?
To convert AVCHD/AVCHD 2.0 MTS to MOV,with Aunsoft MTS Converter for Mac, the advanced technology and the clear interface it use make the timesaving conversion process effective and efficient with only 3 or 4 steps.
http://www.aunsoft.com/mts-converter/
Deleting files from the Sony HDR-SR1 Camcorder Hard Drive
hi Dstein556.As long as the files are related to the films and any other files you have saved,then yes you can.but if you are still not happy to do this then just delete mts files first and check to make sure all is well,if so then delete the cpi files.again if your still not sure then,then just copy the files mts cpi to a disc.then when you have done that.if anything goes wrong you can put the files back if needed.or if you have enough space with leaving the mts and the cpi files on there then just leave them there.but what ever you do will be at your own risk.
After I formatted using windows
You need to format camcorder hard drive through Format option in camcorder menu itself.
Please check camcorder menu and hard drive section for Format option, this will delete all files on hard drive and solve your problem.
Thanks.
Sony Handycam HD 1080 HDR-SR5E ---Retrieving deleted files from handycam
Deleting files from camcorder is just like clearing the recycle bin or Trash onyour comptuter. The data itself isn't deleted, just the area containing the deleted data is also now marked as free space so it is available for any new data to be written there instead. So a simple delete won't make your videos erased permanently.As a result, you have chance to retrieve those deleted videos as long as the video data on your camcorder(memory card or hard disk) are not written over. And the best way is to try some video recovery software, recommended Asoftech Data Recovery as it helped me before, the program can also recover photos and music.
video photo recovery programFirst of all you need to install the program on your computer, then connect your camcorder (memory card or HDD) to the computer and start to recover your deleted videos.
Is it possible to undelete files on a Sony HDR-SR1 Camcorder?
The answer is YES.
Power off your camcorder, take the memory card or hard drive out of your cam, and connect it to your computer as it should appear as a "Removable Drive" or put the card in a card reader attached to your PC.
Then install this software Wondershare Photo Recovery (recover videos and audio files too) on your computer. Then start to scan and see if your deleted files can be got back. Get the program from:
For Windows Version
For Mac version
Remember - Do NOT try & write anything back to your camcoder(card or disk) until you can recover your files safely! Regards
