20 Most Recent
Acer AL1917W LCD Monitor Questions & Answers
Monitor black screen
To me this sounds like whats called "bad caps" problem. The capacitors in the PSU have gone out of tolerance and the back light is switching off. If this is the case you will need a workshop repair or if you know how to solder you could replace the capacitors in the PSU for the back light.
I have acer al1917w A monitor but no sound
There is no sound driver, they are speakers, they work off of the audio output jack on the back of your PC, on the motherboard. If you have the sound drivers installed for the motherboard, and no sound, then you have plugged the monitor audio cable into the wrong jack on the PC, or you have the settings wrong just as MIKE said above.
Yesterday, a white line appeared in the middle of my screen.
It is most likely a fault in the LCD matrix which makes up the screen. I had one on my 22 inch and it was green. I smacked the left side hard on which it was closest to very hard and it cleared it. If it stays on, take it back if under warranty.
Monitor colors lack contrast
Try using a preset picture setting & then compare that to your manual setting seems like you have gone out of sync.
Acer AL1917W LCD monitor powers up but no image at all.
The CPU and PSU, have absolutely nothing to do with a monitor. HERMAN has the correct response. For the info you posted.When you have a video problem, you post what the motherboard is or what model PC, the graphics card, and what drivers you have installed.
Acer moniter model AL1916
Check the cables and the computer connection VGA outlet.
If doesn't work and your monitor is under warranty ACER will repair your monitor for free.
If not, the better option is get a new one instead of repair due the high cost.
Acer display drivers for mac-mini ?
hi, may I know how are you connecting the mac-mini to the display? if it is VGA, that is the highest resolution it can go. But if you're connecting it via HDMI or DVI-D, it can reach its highest resolution for the monitor. did have similar problem last time, but solved by using HDMI-DVI cable.
I bought a used ACER H213H TV, it did not have a
If you still have your instructions for the universal remote. Check in there and it should have a section for your tv or model not listed and how to do a search with your remote to find the tv. Then it will store it and you will be able to use the remote.
My monitor comes up during
You might have it connected using the wrong port on the back of your computer. The monitor will display the BIOS and post messages but once it gets to windows it will turn off. The other possibility is you need to either reload the driver for your video card, change the default display device in the bios, or replace your video card.
My Acer AL1917W LCD monitor shows power good, but
Dying power supply due to bad caps will be more likely the cause.
If you are going to DIY and already try the monitor with another PC, and have proper tools and know safety precaution then please read on:
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply (they should be replaced in a set), blown fuses; poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed ACER monitors to get some ideas what to look for: http://s807.photobucket.com/albums/yy352/budm/
Post back what you see inside so we can guide you further and it will help out other people in the future also.
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors: http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC
