20 Most Recent Samsung LNT3242H Television Questions & Answers
I HAVE A SAMSUNG LNT 3242H FROM CANADA NO SOUND NO COLUR I WANT TO RESET IT
Check with Samsung, that unit should be covered under the class action lawsuit settlement regarding bad power supplies that were install in many Samsung TVs. You can get additional information and contact numbers herehttp://www.ccl-la.com/blog/index.php/samsung-has-reached-a-settlement-in-class-action-lawsuit-over-faulty-tv-power-supplies/
12/24/2018 3:15:17 AM • Samsung LNT3242H... • Answered on Dec 24, 2018
I have a tv that wont turn on. the power button
what is the make and model?
12/4/2017 10:02:57 PM • Samsung LNT3242H... • Answered on Dec 04, 2017
The color on my Samsung LNT3242H TV suddenly is
Go to settings in menu and Reset to Factory settings...Hope this works
10/27/2017 10:50:38 AM • Samsung LNT3242H... • Answered on Oct 27, 2017
Samsung LN-T3242H
Those blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. http://electro-medical.blogspot.com/ http://homenol.blogspot.com/ http://electronicshelponline.blogspot.com/ If blinks continue without any pause, the main board is faulty. Search the site by type in the "brand name" to your device, [Exclude the model number] in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
6/26/2017 2:08:57 PM • Samsung LNT3242H... • Answered on Jun 26, 2017
Samsung LN-T3242HX
Hello Compgeek09, It appears that one of the CCFL lights might have broken behind the screen and that is why the TV would turn on for 1 second and goes off after. The noise you are hearing could peaces of shattered or broken light and you would have to remove the screen and to be able to fix it, if you are up for the challenge. Let me know if you required further assistance.
6/11/2017 12:41:42 AM • Samsung LNT3242H... • Answered on Jun 11, 2017
HI I have a 3 yr old Samsung LN3242 LCD Tv. Last
Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis. http://electronicshelponline.blogspot.com/ To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement. To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself. If so; the main board should be replaced. To some models of sets, all these section circuit will be integrated at its main board. If this is the case, you have to replace the main board.
6/10/2017 8:56:12 AM • Samsung LNT3242H... • Answered on Jun 10, 2017
0answers
Samsung lcd tv power cycling and not coming on
Fault to the main power supply regulator section. Either it will be a separate board, or the part of main board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. http://electro-medical.blogspot.com/ http://electronicshelponline.blogspot.com/ It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and time. Even though you can make it right, it will cost around an amount equal to the cost of a new board; including the cost of (spare parts + service charge) More to say, most of the spare parts to it will be difficult to get from open electronic spare part market. This is true to most of the flat panel TV power supply boards; irrespective of its brand and screen size. Never think, that a TV works one only with some capacitors. Some people thinks so.
1/22/2016 9:58:08 AM • Samsung LNT3242H... • Answered on Jan 22, 2016
How to fix an intermittent white screen on a Samsung television?
Ask them to replace the t-con board. It could be a defect one.Good Luck. Serge.
10/1/2015 6:03:12 AM • Samsung LNT3242H... • Answered on Oct 01, 2015
Screen went black no picture how to fix
If this is related to no picture or sound, then the power supply in many of these Samsung's TV's have under rated capacitors installed causing them to bulge or fail. If you are out of warranty and cannot fix it yourself, get someone who understands electronics to verify the problem and fix it.
3/3/2015 3:54:13 AM • Samsung LNT3242H... • Answered on Mar 03, 2015
Does my samsung LN-T324H have a built in digital tuner for antenns usage?
Just for added clarification, remember to use the "Air" connector at the back when using an antenna and the "Cable" connector for the cable box or wire. You can download the manuals from Global Download Center for final setup.
3/3/2015 3:46:50 AM • Samsung LNT3242H... • Answered on Mar 03, 2015
Samsung lnt3242h red
check all your input cables & sources.If that doesn't solve the issue you may need to replace MAIN PCB, several part numbers listed at this site (correct part # dependent on your complete model#) https://www.encompassparts.com/model/SMGLNT3242H/_/_/Samsung/LNT3242H/LCD_TV also check this site: http://www.shopjimmy.com/catalogsearch/result/index/?q=lnt3242h&tv_brands_select=Samsung&tv_models=Samsung+LNT3242HTX%2FXAA Again, you will need your complete model# for proper part# & pricing.
1/3/2015 4:48:30 AM • Samsung LNT3242H... • Answered on Jan 03, 2015
0answers
LIGHTNING DAMAGE
It is not predictable about which component/s might have damaged due to lightning. Contact the authorized service centre for Samsung. Gopakumar Gopalan Google
3/31/2014 5:49:43 PM • Samsung LNT3242H... • Answered on Mar 31, 2014
TV turns on only for the display to shut off.
Main board fault. Contact any service technician. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" will make surf easy. http://electronicshelponline.blogspot.com/
3/24/2014 2:55:47 AM • Samsung LNT3242H... • Answered on Mar 24, 2014
Televison & Video Logo
89 questions posted
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
View Most Popular
LN Samsung
  • LN Samsung
Most Popular Question
parents going throw out
  • Televison & Video
