20 Most Recent HP LaserJet P3005 Printer Questions & Answers
Printer is not initialise error jam inside top
Hello pls clean all the 3 no of sencors sitted below the PIU unit your problem will be resolved 100% personal experiance...........Regardsjm
12/21/2023 10:17:31 AM • HP LaserJet... • Answered on Dec 21, 2023
2answers
Vertical line on page from HP P3005
clean the drum of the toner with tissue paper and reinstall hopefully it will resolve the issue
12/9/2022 9:43:29 AM • HP LaserJet... • Answered on Dec 09, 2022
I have a two year
You arn't clear whether this message appeared with the old toner cartridge or just with the new cartridge.
If this message just appeared with the new cartridge and not the old one, take it back and get a replacement cartridge.
If the message also appeared with the old cartridge, the printer has a problem with the drum ground connector on the high voltage power supply.
7/21/2022 2:52:41 PM • HP LaserJet... • Answered on Jul 21, 2022
How do I find the MAC Address for a HP LaserJet
Print out the configurationpages and there you'll find the MAC adres.Use the arrow down button to scroll to the informationmenu, scroll down to "print configuration" and press the green button.
11/10/2021 7:20:09 PM • HP LaserJet... • Answered on Nov 10, 2021
Standard top bin full remove
Plastic flags in the output bin can get stuck
1/5/2020 4:24:53 PM • HP LaserJet... • Answered on Jan 05, 2020
Standard top bin full remove paper
Greets!
Firstly, is the exit bin full of paper? If it is, just remove it.
If not, then it's going to be a sensor that recognizes the paper amounts in the exit tray. Check for broken plastics and possibly stuck plastic flaps in the exit tray.
If it's neither of those, try turn it off, unplug, then reverse.
Other than that, if no go, then it's an internal sensor issue. At that point, probably the best bet is to replace as repair costs would outweight a new unit cost most likely.
12/4/2019 8:42:47 PM • HP LaserJet... • Answered on Dec 04, 2019
2answers
How to remove and replace
Hi Adam,
I suspect that you are talking about the tray 2 pick up roller. Here are the directions for that:
1.)Remove paper tray
2.)Unlock left locking tab and rotate forward untill bushing slides off
3.)Remove black plastic roller retaining bracket
4.)Slide roller to the left untill right side of shaft clears the bushing
5.)Lift roller out of printer
6.)Place spring loaded end of roller shaft into left housing
7.)Slide roller to the right and rotate until roller locks into pickup shaft
8.)Reinstall black plastic roller retaining bracket. Left side first.
9.)Reinstall left bushing and lock into place
Let me know if you where sucessfull,
Printer Piete
www.allprotech.com
7/16/2019 8:12:14 AM • HP LaserJet... • Answered on Jul 16, 2019
2answers
My HP P3005 prints blank pages
Please check the cartridges it see if the toner is finish,clean the print head because it may be block up or you can replace it if it is damage.
3/19/2019 9:38:17 AM • HP LaserJet... • Answered on Mar 19, 2019
I'm trying to get paper
That sounds like to me that the pick up rollers are not pulling the paper. Replace the rollers.
10/2/2017 6:11:58 PM • HP LaserJet... • Answered on Oct 02, 2017
Hp p3005 print cartridge stuck right side
Toner Cartridge Drive need to be change
5/30/2016 12:53:27 PM • HP LaserJet... • Answered on May 30, 2016
Jam inside top cover 13.05.00 also change fuser
To remove paper jam. Just remove the toner cartridge and pullout jammed paper. If still coming paper jammed error message. Switch of the printer and the printer will roll over the paper jammed.
Changing of fuser drum is required if the print out came with the black strips. This happens when you print large volume of printing jobs.
3/25/2016 7:47:38 AM • HP LaserJet... • Answered on Mar 25, 2016
2answers
49.2f9d error hp laserjet 3005dn
Most times a 49.xxxx error on an HP printer is caused by either the print driver, firmware or the print job itself.
If it happens when printing a PDF file try sending the file to the printer as an image.
Upgrade the print driver and the firmware.
You may need to disconnect the printer from the pc or network, power it off and pull the plug for a couple of minutes to clear the error.
If it's a network printer it would be a good idea to check the printer queue for any jobs still in it and delete them before powering the printer up again.
11/2/2015 1:28:20 PM • HP LaserJet... • Answered on Nov 02, 2015
50.9 fuser error
check cables connectivity otherwise replace the fuser
5/25/2015 3:53:32 PM • HP LaserJet... • Answered on May 25, 2015
When printing duplex the even pages print portrait
This could be a setting on the printer, in the driver on your computer, or the document you are printing. First, try printing a different document and see if the problem persists. Reset the printer to factory default settings, also referred to as a cold reset. HP has instructions on their website here: HP LaserJet 2300 Printer Series Resetting the Printer Cold Reset You can also go into the printer driver on your computer and reset settings there, or uninstall and reinstall the printer.
3/8/2015 5:14:43 PM • HP LaserJet... • Answered on Mar 08, 2015
HP3005dn hard reset
Power off and then hold down check mark button as you power up. This resets the paper settings.
1/31/2015 4:32:00 PM • HP LaserJet... • Answered on Jan 31, 2015
2answers
I change my toner, and i have msg. "ORDER
Must be an aftermarket or refilled toner cartridge. These toner cartridges have a chip on them that must be changed when refilling or remanufacturing the cartridge. It looks like you got a cartridge where the chip has not been changed. I would return it for another cartridge.
Good Luck and Thank You for using Fixya.
Wheatland Services
11/26/2014 9:12:38 AM • HP LaserJet... • Answered on Nov 26, 2014
How do i change the toner cartridge?
Just lift up the Toner Access Door, take out the toner and replace with a new toner cartridge.
11/26/2014 9:10:45 AM • HP LaserJet... • Answered on Nov 26, 2014
2answers
Hp laserjet p3005dn printer taking 3 papers
Your problem description is not clear, but based on experience I bet that your printer is taking three sheets of paper at a time. The pickup roller in tray 2 and the separation pad in the tray are probably worn out. They are easy enough to replace. You can verify that printer works properly by printing from manual feed tray and if that works ok then above solution is likely your fix.
11/26/2014 9:09:51 AM • HP LaserJet... • Answered on Nov 26, 2014
Hp laserjet 4015 error code 13.98
chek for papers under toner area and check sensors
11/22/2014 10:25:36 PM • HP LaserJet... • Answered on Nov 22, 2014
HP LaserJet P3005 Printer Logo
274 questions posted
k24674
Grand Canyon Tech
Grand Canyon Tech
View Most Popular
LaserJet HP
  • LaserJet HP
Most Popular Question
standard top bin full remove
  • Office Equipment & Supplies
