20 Most Recent
Acer Aspire 3690-2196 Notebook Questions & Answers
Lines in the screen
The screen is going bad. You will have to get a new screen or get it repaired by the company.
Tengo un power edge 2900
verifica en el BIOS, talvez ahora cuando arranca esta buscando arrancar por medio de la "red" o carta de red, tienes que cambiar los settings en el BIOS.
The 0 tru 9 blue
You have probably inadvertently pressed a key marked with "NumLK" this is usually in blue or brown text on your keys. If you press this key again, you should get your normal letters back.
Hope this helps;)
Acer Aspire 4720Z will not power on
check all power leads
or if its trying to start or starts then shuts down check for over heating, check battery,check fuse in plug.
check fan to make sure its running.if not clean it.
DOWNLOAD LOGITECH WEB CAM VUJ11
So try taking that worthless rubbish off and try something less intrusive that actually works, and best of all, its free, Avast free edtion.
Seriously, McMucky has a lot of issues with Acer bloatware and we always recommended uninstalling as they never released fixes for the problems.
Driver for aspire 3690
surf to http://www.acer.com/worldwide/ and choose your country, and the goto Support and there you should see "Drivers and Manuals" and from there you write in your computer name / model etc etc
Hi i have an acer aspire 3690 and cannot boot the
Hello
Thank you for using FixYa for your problem
If you receive the “unmountable boot volume” error and have an installation disk, you still have a chance to save your system.
1. Insert your XP installation disk into an optical drive and boot up your computer.
2. When you see a welcome screen, hit the R key on your keyboard. This will enter you into recovery mode with a DOS prompt.
3. Now type chkdsk /p and hit Enter. This will launch a utility which will check for errors on your hard drive.
4. After the process is done, type fixboot and hit Enter to repair any damaged boot files which may have become corrupted. When asked to say yes or no, type the Y key on your keyboard.
5. Type exit and press the Enter key to reboot your computer.
If all went well, you should now be able to boot back into Windows without a problem!
Please rate our solutions and if you still have problems please call back for more ideas to help you
Thanks
Richard Scott
Technical Support
New Zealand
Webcam info
now you need install the youcam to use your camera
Downloading skype onto my acer aspire one netbook
For aspire one you need to download the Fedora 7 package from the Skype Website.
Afterwards, just do what your aspire asks you to do. When everything is installed, just press alt+F2, type in "skype", en press "Run". Skype will start up. That's it
Acer Aspire 3680 Complete Restore
http://www.acerpanam.com/us Go to that website and click on "eRecovery Disc Purchase". Acer does not come with recovery discs. It only comes with a recovery partition from which you can make recovery discs. If they discs were not made you'll find the provided website useful. If you're trying to recover from your recovery partition, then continuously hit the F11 key at startup. This F11 option is not always displayed. If this doesn't work then your hard drive is corrupt or damaged and you will need the discs (and potentially a new hard drive).
I NEED A REGISTRACION KEY FOR ERRORWIZ PLIZ
If you need a registration key you need to make sure you get the product licences. If you are using windows operating system make sure you have the recovery CD or the product key sticker on your laptop
