20 Most Recent Vivitar ViviCam 8400 Digital Camera Questions & Answers
Vivi8400 driver
Do you really need a driver? The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries. Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo management program such as Picasa ( http://picasa.google.com ).
6/15/2014 9:31:05 PM • Vivitar ViviCam... • Answered on Jun 15, 2014
Card locked comes up can not take a picture
Look at your memory card. SD cards have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
5/3/2014 12:58:06 PM • Vivitar ViviCam... • Answered on May 03, 2014
Vivitar 508nhd firmware upgrade?
Sorry, there is no firmware upgrade available, nor is there a way to upgrade the camera even if one were available.
12/29/2013 7:39:27 AM • Vivitar ViviCam... • Answered on Dec 29, 2013
Update firmware download
Vivitar lists no firmware updates for the 8400. See http://www.vivitar.com/products/1/digital-cameras/17/vivicam-8400
10/12/2013 2:25:10 PM • Vivitar ViviCam... • Answered on Oct 12, 2013
Can i use any sd card in my vivicam 8400 camera
Yes, you may use any SD card. Make sure it's an SD card and not an SDHC card.
12/29/2012 4:34:25 PM • Vivitar ViviCam... • Answered on Dec 29, 2012
3answers
I NEED SOFTWARE FOR MY VIVITAR 8400
http://vivitar.com/products#Digital Cameras/24/17/Support
11/24/2012 1:47:52 AM • Vivitar ViviCam... • Answered on Nov 24, 2012
How to fix card error on vivitar vivicam 8400 digtial camera
see this and fix it. God bless you The reset button is usually located on the base or the back of the camera. The reset button sets the camera back to the original factory settings. If the camera still does not power on, contact Canon support for servicing and repair.
10/17/2012 7:57:31 PM • Vivitar ViviCam... • Answered on Oct 17, 2012
I have lost my Vivitar disc I got with the camera vivicam7340 - I now need it for my computer so I can down load my photos... where do I get it from ?
You don't need the Vivitar software.The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as Picasa.
10/6/2012 3:16:07 PM • Vivitar ViviCam... • Answered on Oct 06, 2012
2answers
Free software for 7340 vivicam
You don't need any special software.The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or, despite what I said first, you can use any photo cataloging program, such as Picasa.
10/6/2012 3:10:28 PM • Vivitar ViviCam... • Answered on Oct 06, 2012
I have lost my cd
Go here and click on "Vivitar Experience Software".You don't really need the Vivitar software. The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program, such as Picasa.
3/27/2012 6:50:12 PM • Vivitar ViviCam... • Answered on Mar 27, 2012
My camera doesnt record audio.
The 8400 is designed primarily as a still camera, with some video capabilities grafted on. As such it captures images not sounds. You can add a soundtrack using video-editing software on a computer but you cannot record one on this camera.Sorry if that wasn't the answer you wanted to see, but that's the way it is.
3/27/2012 6:46:58 PM • Vivitar ViviCam... • Answered on Mar 27, 2012
It does not charge, where can I buy a new one?
There's nothing wrong. The camera isn't supposed to charge batteries. If you use rechargeable batteries then you must charge them using a separate charger.
3/27/2012 6:43:12 PM • Vivitar ViviCam... • Answered on Mar 27, 2012
No instructions
You can download the manual here.
3/22/2012 6:53:26 PM • Vivitar ViviCam... • Answered on Mar 22, 2012
Need the software for vivicam 8400 camera
You don't need any software to use your camera.The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or, despite what I said first, you can use any photo cataloging program, such as Picasa.
3/22/2012 6:52:15 PM • Vivitar ViviCam... • Answered on Mar 22, 2012
Cd for vivicam 8400 ruined
3/22/2012 6:50:41 PM • Vivitar ViviCam... • Answered on Mar 22, 2012
Looking for download softwear for my vivitar vivican 8400
3/22/2012 6:12:31 PM • Vivitar ViviCam... • Answered on Mar 22, 2012
I have a missing usb cable for vivicam 8400
Consider NOT using the USB connection.The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program, such as Picasa.
3/22/2012 6:07:41 PM • Vivitar ViviCam... • Answered on Mar 22, 2012
Card
SD and SDHC cards have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
3/22/2012 6:06:00 PM • Vivitar ViviCam... • Answered on Mar 22, 2012
Vivitar ViviCam 8400 Digital Camera Logo
127 questions posted
Top Vivitar Cameras Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Vivitar Camera Expert? Answer questions, earn points and help others
View Most Popular
ViviCam Vivitar
  • ViviCam Vivitar
Most Popular Question
vivitar 508nhd firmware upgrade
  • Cameras
