20 Most Recent
HP Deskjet D2360 InkJet Printer Questions & Answers
Hp deskje d2360 printer showing offline error
On Printer and faxes, right click on your printer and unselect "Use printer Offline". If "Use printer Offline" is not select, then verify you USB cable.
If I could be of further assistance, let me know. If thishelps or solves the issue, please rate it and give a testimonialfor my response.
My HP Deskjet D2360 keeps going offline. What
First try reinstalling drivers for your printer from original CD, if that doesn't help update your drivers from the Internet.
If none of it helps, try connecting your printer to another computer and see if it will behave the same. If it does, then printer is ready for retirement.
My printer hp deskjet d1360
Click Start and then go to Printers and Faxes (XP), Printers(Vista), Devices and Printers(Win 7)
1. Right Click on your printer Icon
2. Click Open or See What's Printing
3. Click the option that says Printer on the upper left corner of the window that pops up.
4. Make sure the only thing that is checked under that menu is Set As Default Printer.
5. If Use Printer Offline or Pause Printing has a check mark. Uncheck it.
Try printing again. I hope this helped.
How to install
log onto HP website look for dowload type the description of the product and there you can dowlnload your driver.
HP Deskjet D2360
First, try running the installation as Administrator. Right click on the executable and select Run as Administrator. If that doesn't work, go to that registry entry and make sure that System and Administrators have Full Permissions.
I am printing in red but output is yellow
Check the ink levels- it sounds like your Magenta is out- HP deskjets use CMYK to mix the colors- C = Cyan, M= Magenta, Y = yellow, K = intensity (black). Red is usually a blend of Magenta + Yellow- so if you don't have magenta ink in your printer, when you try to print out something in red- it will come out yellow I’m happy to help further over the phone at
https://www.6ya.com/expert/susan_42b401e0b1603d8a
