20 Most Recent
Canon PIXMA iP1800 InkJet Photo Printer Questions & Answers
CANON IP 1300 SERVICE ERROR 5100
ERROR 5100 means that there is some foreign object blocking your ink cartridge carriage that disables it from moving. It may be a piece of paper or a scotch tape or a staple wire. You may try cleaning also the encoder strip with a moist tissue paper. Furthermore, you may also try cleaning CAREFULLY the contact points of the cartridge holder and the cartridge itself (those shiny bronze pins) with a moist lint-free cloth.
"The printer is offline.
Check that
Issues or errors within the operating system might also cause printer offline issue. Users having
offline printer issue are advised to clean the registry of the system, check integrity of the system files and also remove any malware infections using an updated antivirus program. Users must also stop the printer service active on the system and restart it as the issue might be because of errors. Removing the errors from the system would get the printer working without issues.
PRINTER CANNOT PRINT
This happens because ink jet printers have a waste ink reservoir and if its full you need to
get it cleaned. I recommend you don't do this yourself because you can permanently damage the printer if you don't know what are you doing. I recommend calling the canon technical support line and asking them where the nearest service center is located:
Canon USA customer technical support* options:
- Toll-free live technical support** Monday through Friday 10:00 AM ET to 10:00 PM ET (excluding holidays) at 1-800-828-4040
If you have any other questions, please let me know.
Why there is a problem of light flashing (orange
Hello there!
Might problem with the waste ink counter. Should you clean or replace before resetting but usually you can get away with it by resetting once.
1. Turn your printer OFF
2. Hold down RESUME and then hold down POWER
3. Release RESUME
4. Press RESUME twice, then release POWER
5. Let green light blink until printhead has finished moving
6. Select functions below with RESUME, execute with POWER]
If you need further assistance, please let me know.
Regards,
fossildude
Error 5100
Error 5100 mean carriage error. Possible problems in:
- Carriage unit
- Timing **** strip film
- Logic board assembly
- Carriage motor
How can i install a canon ip 1900 in windows 98?
Try going to the Canon website and download your software. (
http://software.canon-europe.com/products/0010647.asp )
Uninstall any software that you may already have install for the Canon by going to ' add & remove programs ', uninstall your canon printer by going to ' printers & faxes, disconnect your Canon printer from your computer.
Reboot your computer.
Install the Canon printer software that you downloaded.
Hook up your Canon printer to your computer.
The software should install automatically. If not, re-install the software you downloaded.
I was having a printing on animal care (book) It
itz problem/error of print pooler..
often happens due to data resent viz. reprint/overload/document mismatch/page error and so on..
itz very common..don't panic..!!..
snatch out all the paper(s) in the tray (but not which is
printing)..set all the document in the print pool to delete..just turn
off the printer..restart the system..
hope it'll b fine..
best to seek guidance of ur system admin/vendor....
My canon ip1900 says paper jam, gives 3 orange
Hello there
You may not see a paper jam.
This may work for you, it has worked for many here I given this advice so gave it a try it could work for you.
Generally when this happens, something has fallen into the printer, or a piece of paper has been jammed in there.
First step, remove the ink cartridge, and turn the printer upside down and gently shake it, see if anything comes out.
If nothing goes, or you can't hear anything rattling around, get a piece of cardstock paper (60lb or heavier) and gently push this through the printer, to see if it will help push out what might be stuck in there.
And gave the rode that the ink slides on a good clean and maybe a bit oil on cloth and wipe the rod with it.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
