20 Most Recent Konica Minolta Magicolor 2530 DL Laser Printer Questions & Answers
Konica Magicolor 2530DL printing size mismatch....
check your media guides and check the user setting of the printer at the printer and compare at computer printer properties Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
12/21/2017 12:46:08 PM • Konica Minolta... • Answered on Dec 21, 2017
Magicolor 2530dl
IF YOU LOOK AT THE PRINTER FROM THE TONER BOTTLE END THERE IS A SMALL CLUTCH IN THE TOP LEFTHAND REAR CORNER OF THE PRINTER.
YOU WILL NEED TO REMOVE THE TOP COVER TO ACCESS IT.
IT IS BEHIND A PLATE BUT FASTENED TO THE MAIN FRAME OF THE PRINTER.
YOU NEED TO SPRAY INTO IT WITH SOME LUBRICANT LIKE WD40 NOT OIL.
THIS CLUTCH GOES RUSTY AND DRIVES THE CAROUSELL SO GIVES 15H CAUROSELL ERROR
2/5/2017 1:22:09 PM • Konica Minolta... • Answered on Feb 05, 2017
2answers
Not printing correct size
check the media Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
7/9/2016 10:54:44 PM • Konica Minolta... • Answered on Jul 09, 2016
Installing pickup roller
Service manuals electronic components datasheets and equipment schematics... try this site for manual Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
7/2/2016 8:45:58 PM • Konica Minolta... • Answered on Jul 02, 2016
Media jam fuser
replace the fuser unit. and replace the transfer roller and belt, Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
5/5/2016 4:09:06 AM • Konica Minolta... • Answered on May 05, 2016
My 2530dl prints blank pages then gives a media jam fuser error
I literally just fixed the same problem in my 2530DL. Look at section 6.3.23 in this service manual for a nearly identical model http://printer.konicaminolta.com/drivers/other/Manuals/24_25/fs_2400s.pdf and notice the "Precaution for Reinstallation" This Registration Roller Solenoid is an electromagnet-activated lever which controls the timing of the page's movement through the printer. The manual notes that the space between the "flapper" and gear is critical for proper timing. In my case, the tiny foam pad at the bottom end of the flapper had apparently become compressed over time, resulting in the spacing going out of tolerance. I removed the foam pad and replaced it with layers of electrical tape, adding layers until I found the thickness needed to make the printer work correctly (6 to 8 layers). Then I removed the tape and glued in a piece of hard rubber of the same thickness. (Tape is only a temporary measure as it can compress or become sticky after a while.) Everything is back to normal now! Good luck!
4/13/2016 12:17:54 AM • Konica Minolta... • Answered on Apr 13, 2016
Screen displays processing
try this site Self Help Product Support Konica Minolta Business Solutions Inc Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
1/25/2016 4:14:27 AM • Konica Minolta... • Answered on Jan 25, 2016
Toner Life End
replace with a new one. Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
1/24/2016 4:25:06 AM • Konica Minolta... • Answered on Jan 24, 2016
Media jam fuser
replace the fuser unit Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
1/24/2016 4:16:29 AM • Konica Minolta... • Answered on Jan 24, 2016
Paper train not level
what do you mean not straight?? the document come out skewed? if so check the rollers for that draw also might be something in the paper path the paper hits causing it to skew Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
1/18/2016 3:54:09 AM • Konica Minolta... • Answered on Jan 18, 2016
Remove 2530dl fuser
12/29/2015 7:56:24 PM • Konica Minolta... • Answered on Dec 29, 2015
Printes with white streaks
the laser is being blocked for that color remove the image units and clean the slit glass that the laser goes though Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
12/28/2015 9:51:10 PM • Konica Minolta... • Answered on Dec 28, 2015
Print comes out offset to the left by 1.5" on Magicolor 2530DL
check and make sure correct media is selected in print properties and select at the machine Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
6/15/2015 12:00:59 AM • Konica Minolta... • Answered on Jun 15, 2015
WHAT IS KOICA PRINTER TRANSFER BELT ERROR
The transfer belt is what places the image on the paper, which the belt receive from the drums. Get a new one or re-install the belt properly. Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
5/19/2015 3:54:16 AM • Konica Minolta... • Answered on May 19, 2015
Prints are offset on Mac
On windows it is ok? Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
5/19/2015 3:50:57 AM • Konica Minolta... • Answered on May 19, 2015
Not printing full page
Verify the printer paper size settings and on PC the paper layout settings.
1/3/2014 2:34:36 PM • Konica Minolta... • Answered on Jan 03, 2014
0answers
Need to download print driver, not coming up in
GO HERE FOR DRIVER onyxweb.mykonicaminolta.com/OneStopProductSupport?appMode=Public CANT PUT IN FULL LINK WONT POST
8/30/2013 12:24:51 AM • Konica Minolta... • Answered on Aug 30, 2013
Minolta 2530DL. This piece of junk has another
Thank you for your kind reply.I'm not going by the readout - but by the fact that bits of paper get stuck under one or two of the final feed rocker/rollers,,,, and are a bu@@er to get out.Kinolta Customer Service - AND MANAGEMENT - are aware of just how badly designed this paper feed system is, but will do nothing about it.I have had to virtually strip this piece of carp down, just to give me a little more access,,,, even then, its more than a struggle.Thanks again.
8/23/2013 8:05:21 AM • Konica Minolta... • Answered on Aug 23, 2013
Konica Minolta Magicolor 2530 DL Laser Printer Logo
134 questions posted
Top Konica Minolta Office Equipment & Supplies Experts
Norman Weimar
Norman Weimar
ZJ Limited
ZJ Limited
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
View Most Popular
Magicolor Konica Minolta
  • Magicolor Konica Minolta
Most Popular Question
konica minolta magicolor 2530dl streaks
  • Office Equipment & Supplies
