20 Most Recent
Samsung LNT5265FX 52 in. LCD Television Questions & Answers
Purple dots on the screen
call samsung, probably bad capacitor needs to be replaced, mine was fixed for free even out of warranty. samsung arranged for in home service for free. Thanks Samsung.
3/11/2019 3:02:38 AM •
Samsung...
Answered
on Mar 11, 2019
Tv screen resolution
Check your menus. There should be one menu that allows you to resize the picture to the screen size. (Most likely a submenu in the video menu).
6/16/2017 5:41:34 AM •
Samsung...
Answered
on Jun 16, 2017
HDMI port not working
you can fix this by replacing the main pcb. I can get you a part number with the full model code and version number.
4/17/2014 11:24:59 PM •
Samsung...
Answered
on Apr 17, 2014
Samsung led tv has flickering
Flickering can be occurred to many reasons. If you wish to get more details, about this, check this site. From back-light to adjustments might cause this.
Pull up previous posts by its left sidebar, or type in the
brand name and model number to of your set, to its search box, and press '
Enter'
or view it in
Mosaic / Timeslide option.
9/16/2013 7:20:55 AM •
Samsung...
Answered
on Sep 16, 2013
Works fine for 1 or 2 weeks, but some times I try
There is a high possibility that the components over a period of heating and cooling, tend to bring on a problem of dry soldering. So my advice is to check the set for some loose joints that have played on to give you these erratic shut downs or poor performance. The best way to check for loose connections is to tap lightly when the set is powered on, if there is change while tapping then it seems that there are DRY solder joints. Remove main plug, the covers - with caution of high voltage, check for dry joints, and use a good soldering iron to solder all suspected points. Sometimes the fault occurs when the set warms up; if so you can simulate the heat using a hair dryer on the suspected areas, try with the power supply, distribution, Processor controller, driver controllers on the A/V related sections. Also the use a FREEZE-IT spray can simulate the components to cool and show up the fault. It can also be related to WEAK ELECTROLYTIC capacitors as the value can reduce in time.
10/20/2011 2:52:29 AM •
Samsung...
Answered
on Oct 20, 2011
My t.v. will not power
It's likely the power supply board. I had the same thing happen. I was able to open up the television and locate a couple of blown capacitors on the power supply board. The blown capacitors have a bulging end. When I identified this was the likely problem I was able purchase a kit online with all the replacement capacitors (about 10 total) , basic directions, a small bit of solder, and a solder wick. I only had to supply a solder iron and a screwdriver and replaced only the 2 bulging capacitors. It seamed to work for me. There are lots of videos on youtube and message that show people and discuss how to replace capacitors.If you find blown capacitors...here is where I got the parts. But I wouldn't buy the kit unless you see at least 1 blown capacitor. It might not work but you are only out $10 in parts if it works.
http://www.karmtec.com/Search.aspx?Search=LNT5265FX
9/29/2011 7:46:10 AM •
Samsung...
Answered
on Sep 29, 2011
