20 Most Recent HP Officejet Pro L7680 All-In-One Printer Questions & Answers
2answers
Can't fax in or out with my L7680
386
387
388
389
390
391
392
393
394
395 The machines were unable to complete the handshake.
*Try to send the fax at a time when telephone line conditions have improved
11/16/2022 8:29:13 AM • HP Officejet Pro... • Answered on Nov 16, 2022
3answers
Says printhead prblem,
Most generic inks will not work in this machine, If you are using genuine HP ink, you have gotten a bad printhead, if you are using generic ink you may have just ruined a new printhead.
11/2/2022 11:09:46 AM • HP Officejet Pro... • Answered on Nov 02, 2022
2answers
The printer cuts off the
Yes, most likely your application's margin settings are incorrect. Try printing a test page - NOT from the application. If this is Windows, go to printers in control panel, right-click on the subject printer, choose Properties, then click the Print Test Page button. You should get the standard Windows printer test page with the logo at the top and all the printer specifics below. If the test page is also cut off, look around in the HP-provided software for any margin and/or page size settings that are incorrect, such as A4 paper when it should really be Letter size.
2/8/2022 4:58:47 AM • HP Officejet Pro... • Answered on Feb 08, 2022
I bought and replaced the
please take your print head and get it tested or get it replaced, or you could take your printer to a local HP service centre and get it checked, rather than trying to fix it yourself you mite damage the sensors for the print head.
11/30/2021 5:05:42 AM • HP Officejet Pro... • Answered on Nov 30, 2021
My HP L7680 printer gives message "print carriage access door or ink cartridge cover is open" but it isn't any ideas how to get rid of message and get printer to work
To resolve print carriage access door or ink cartridge cover open error just dial toll free number HP Customer Service Phone Number +1-800-281-3707 24*7 available for your service with the help of qualified technicians. HP Customer Support Phone Number 1 8002813707Help
7/26/2021 7:06:39 AM • HP Officejet Pro... • Answered on Jul 26, 2021
HP printer error code 0003
please clarify what is the exact thing the printer is doing whenever you get this code>where do you see this code isiton the computer or on the screen of the printer>this might have something to do with the ink systems
4/20/2021 10:23:15 AM • HP Officejet Pro... • Answered on Apr 20, 2021
My HP Officejet 4500 won't
I also faced the same problem. You can try the following steps to fix this issue:- Check ink cartridge- Reset your printer- Clean print-heads- Check the printer's color optionYou can visit the following link to read these steps in detail:https://www.techsolutionforall.com/blog/facing-issues-hp-officejet-4500
3/6/2021 5:29:12 AM • HP Officejet Pro... • Answered on Mar 06, 2021
3answers
I am trying to connect my laptop to my hp printer
It's the password you used to setup security in your wireless router.
2/29/2020 4:20:07 PM • HP Officejet Pro... • Answered on Feb 29, 2020
2answers
Trying to install software for HP officejet L7680 on widows 7 system 64 bit. When installed printer and fax works well. When attempting to scan error message appears.
when installing the drivers turn off the antivirus software. download the latest drivers from HP, also down load the HP software on the main software page. this is the latest HP firmware and diagnostic firmware.
10/18/2019 9:35:12 PM • HP Officejet Pro... • Answered on Oct 18, 2019
4answers
Error code 0005FBB6
  1. Turn on the HP All-in-One.
  2. Disconnect the power cord from the back of the unit.
  3. Press and hold the # and 3 buttons simultaneously.
  4. While still holding down the # and 3 buttons, connect the power cord to the back of the unit.
  5. Continue holding the buttons until the Power button blinks.
  6. Follow the instructions that display on the unit to select the language settings.
Then when that's done, try printing, or copying items. If its still not working, check the ink and change those out and this should fix it.
Cloud Striver
If you have further questions email [email protected]
12/8/2018 7:12:20 AM • HP Officejet Pro... • Answered on Dec 08, 2018
0answers
2answers
How do I remove stuck paper
Please follow these steps:
•1 Turn the printer off and on to see if it can automatically clear some or all of the jam. Many printers provide an error-code listing on the front panel display for the area where the jam occurred. If your printer shows an error code, be sure and check the printer manual to see if that identifies the area of the printer where the jam occurred.
•2
Turn off the printer.
•3
Remove any paper trays. Inspect them for wrinkled or damaged paper.
•4
Open any other doors that give access to the printer's paper path and to the toner or ink cartridge.
•5
If necessary, remove the toner or ink cartridge. Place it in a bag or away from light to avoid damaging it.
•6
If you find a piece of jammed paper, remove it by holding it with both hands and pulling firmly (see A). The goal is to keep the paper from tearing. If several pieces are jammed together, try pulling out the middle piece first to loosen the jam.
•7
If the paper does tear, try rotating the roller gears manually to free the paper (see B). Don't force anything, though.
•8
Replace the toner or ink cartridge and paper trays, close any doors you opened and turn the printer back on.
•9
If the printer paper jam message still appears, then there is still some paper in the printer. Reinspect the paper path.
9/12/2017 10:51:25 AM • HP Officejet Pro... • Answered on Sep 12, 2017
I have Windows 7 op sys in my HP computer. My HP L7680 will now not print an Excel file on legal--reduces the size to letter. Help!
Software issue. Contact MS since HP will do nada for you since it is not a printer problem. Maybe your excel program is not really compatible with Win 7. Check it out.
8/24/2017 2:52:55 AM • HP Officejet Pro... • Answered on Aug 24, 2017
Anyone know how to spoof the print cartridges?
I recommend getting a Canon Printer. I had an HP but I was having trouble with the print cartridges also. So, I bought a new printer.
7/1/2017 9:35:01 PM • HP Officejet Pro... • Answered on Jul 01, 2017
HP Officejet Pro L7680 All-In-One Printer Logo
899 questions posted
k24674
Grand Canyon Tech
Grand Canyon Tech
View Most Popular
OfficeJet HP
  • OfficeJet HP
Most Popular Question
error code 0005fbb6
  • Office Equipment & Supplies
