20 Most Recent
HP Photosmart 3210 All-In-One InkJet Printer Questions & Answers
Battery won't charge
Archie, have battery charging system checked at a small electronics shop to verify it is working, if found to be OK the new battery is probably faulty.
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
HPPhotosmart 3210 AIO hangs us with error code of 0xc05d1281
Hi Minnie,This could be because of residue on the Printhead electrical contactsTry the steps below and it should help.Turn off the Printer. 1. Open the Carriage access door.2. Remove the Cartridges4. Move the carriage from left to right 6 times and it should move freely5. Clean the contacts on the Cartridge with lint free cloth. ( Golden dots )6. Turn on the printer and it should say " Cartridge missing or need to be reinstalled "7. Install the Cartridges and close the Carriage door8. the printer should go through alignment processIf this step does not fix, You may try calling HP customer support to check for better options/solutionsHP Customer Care : 1-800-474-6836Regards,Sean
HP printer 3210 all in one will not print
IssueAn 0xc18xxxxx or 0xc19xxxxx ink system error code displays on the front panel. The printer cannot copy, receive faxes, or print. Solution
Press the On button to turn the printer off.
Unplug the power cord from the back of the printer.
Remove all the ink cartridges.
Wait two minutes.
Plug the power cord into the back of the printer.
Press the On button to turn the printer on.
Install the ink cartridges when prompted.
If the error code does not display, the issue is resolved.
If the 0xc18xxxxx or 0xc19xxxxx ink system error code displays on the front panel, service the printer.
HP Photosmart 3210 -Ink System failure - Error 0xc18a0001
In addition to having the ink system failure error 0xc18a0001, my
printer screen also read improper shutdown. After trying most of the
above solutions with no success, I did a search for the improper
shutdown problem. This is where I found my solution!
The solution is under "Printer will not start" the solution post is by
speters9971. "...you can try a sem-full reset to factory default
conditions by 1.
unplugging the power cord while the printer is powered on and 2. press
and hold the OK and Cancel buttons while plugging in the power cord."
This is what solved my problem after hours of searching &
repetitive similar solutions!!! The above solutions did not help; some
of them seemed to be incomplete or irrelevant for my model. I have a
HP Photosmart 3210 All-in-One.
Thank you speters9971!!!!!!!
