20 Most Recent
Brother Multi-Function Center MFC-665CW All-In-One InkJet Printer Questions & Answers
How to clear the fax memory of my MFC885CW ?
This is the procedure trained in the client's manual for this particular machine... Select "Menu"- Select "Fax"- Select "Setup Receive"- Select "Memory get"- Select "off"- Press the stop/leave key. On the off chance that this doesn't work you can play out a reset... Be cautioned that this will eradicate any speed dial settings or numbers you have spared in the machine. Select "Menu"- Select "Introductory Setup"- Select "Reset"- Select "Speed Dial&Fax" and press alright Press "1" to affirm and "1" to reboot the machine. Fill me in as to whether this works. Much obliged. Ref:https://sovinco.com/
12/26/2017 6:37:17 AM •
Brother...
Answered
on Dec 26, 2017
Unable to clean 51
Normal
0
Driver could be corrupt.
Disconnect the printer or at least be sure it is turned off.
I'd do both and reinstall the CD software program that came with
the printer. When the software program asks you to connect the
printer to the USB port, do so and it should again work properly.
Hope this helps. Bud
4/3/2016 11:29:52 PM •
Brother...
Answered
on Apr 03, 2016
Error message of F4
You should have a manual for that device. Message errors are listed, and if you can't locate that information; go on line to Brother at the Web site and seek assistance from the company support.
5/10/2014 4:15:49 PM •
Brother...
Answered
on May 10, 2014
