20 Most Recent
HP Photosmart D7360 All-In-One InkJet Printer Questions & Answers
How do you choose the tray to print from. Photo
Yes there is.
You can see on the printer panel, there is a button for "photo tray".
If the light is "on" it means the button has been pressed and the printer will try to engage the photo tray in the next print job.
If the light is "off" it means the printer will ignore the photo tray.
Cheers,
Ed
Despite a new full original HP Yellow ink
How to Clean the printhead
Open the All-in-One Toolbox:
- Open HP Solution Center (click Start, click All Programs, click HP, and then click HP Solution Center).
- If you have more than one All-in-One installed, make sure to select the correct All-in-One tab in HP Solution Center.
- Click Settings.
- Click Print Settings.
- Click Printer Toolbox.
- On the Device Services tab, click Clean the Print Cartridges, and then follow the onscreen instructions. Three levels of cleaning are available.
I have this code 0xc19a005
This message means that the ink system has failed on your printer most likely caused by the print head overheating. The only solutions available for this issue WAS to either replace the print head or replace the printer BUT ...... DO THIS ::::
NOTE: CHANGE EMPTY CARTRIDGE BEFORE DO THAT:
press and hold the '*' key on the key pad, then press the '#' key and release them both. Then he had me enter '123' to enter maintenance mode. then press the right arrow (beside the OK button) until System Config. menu appear on panel. Then press OK two times to clear the error condition, then cancel two or three times to return to the top menu. Then powered off and back on, print a test page .
Ink System Failure code appears on Hp Photosmart D7360 printer
Hi ok try
I found this I know your error not in here but it may work for
It worth a try nothing to lose and it may work.
I know your error code is not in this but it some times it clean the error with this type of error number you can gave it a go try not harm it
Error code: 0xc18a0201, 0xc18a0206, 0xc18a0306, 0xc18a030a, 0xd0620130, 0x887dd03a, 0xd05d010d, 0xf0af8004, 0xc19ac3ff, 0xc18a050...
Reset the product:
1. Without turning off the product, disconnect the USB cable from the rear of the product.
2. Remove the cartridges from the product.
3. Wait for the 'Insert Cartridges ' message to display on the control panel.
4. Disconnect the power cord from the back of the product.
5. Wait 60 seconds.
6. Reconnect the power cord. If the product does not automatically turn on, press the Power button ( ).
7. Reinsert the cartridges, and then close any open doors on the product.
8. If you receive a prompt to print a calibration page, do so.
9. Reconnect the USB cable to the rear of the product, and then try printing again.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
For 2 years ago I bought a D7360 HP printer in
Hi
Unfortunately there is no way to
set your printer to use zone 2 cartridges or to change the zone as in Brazil which uses inkjet cartridges zone 02 compared to Sweden(which uses inkjet cartriges zone 363) .HP recommends that you use genuine HP ink cartridges. Genuine HP ink cartridges are designed and tested with HP printers to help you easily produce great results,time after time. Please check this manual for further information on ink cartridges:
HP PHOTOSMART D7360
Please do accept this solution and revert for further assistance.
Thanks
Rylee
Ink system failure Error: 0xc18a0301
This comes from fixyourprinter.com:
Error number 0xc18a0301 on HP printers
Follow the below steps on the front panel of the All-in-One printer:
A. - Press and Hold the “Print Photos” & “Red Eye Removal” buttons. Release both buttons. Display should say “Enter Special Key Combo”
B. - Press and release in sequence “Red Eye Removal”, “Print Photos”, “Red Eye Removal”
Display says "enter special key combo"
Press and release in sequence “Red Eye Removal”, “Print Photos”, “Red Eye Removal” .
If "support COxxFN0723BR" appears with "uiaux" message, perform the below steps:
2. Press and release the right arrow button until the display says “System Configuration Menu”. (on C8100 use Touch Screen)
3. Press and release the “OK” button.
4. Display should say “Hardware failure status”. If not there already, Arrow Key over to “Hardware failure status.
5. Press and release the “OK” button
6. Display should say “Hardware failure status: Clear. Press OK to clear”.
7. Press and release the “OK” Button. Message changes to “Hardware failure status Cleared. Press Cancel to continue”.
8. Press and release the “CANCEL” button as many times as necessary, so that, either the “Welcome to Photosmart Express” screen appears, or, the “Ink System Failure” screen appears. PLEASE DO NOT TRY TO PRINT AT THIS STAGE.
9. Using the Power Button, turn the unit OFF and unplug the power cable from back of the printer and wall outlet.
10. Wait 30 seconds for the power to get discharged and then plug the power cable into the wall outlet first and then into the back of the printer
11. Turn the unit on. The printer may display message “USE POWER BUTTON TO SHUTDOWN THE PRINTER” followed by “PRESS OK TO CONTINUE”. Press OK.
12. If the printer has already initialized, then go to the next step. If not, the printer will start the “ONE TIME INK INITIALIZATION PROCESS”. Allow this process to complete and do not interrupt. Once the initialization process is complete, the printer will print out a Diagnostic Page.
13. To verify printer functionality print a SELF TEST PAGE.
