20 Most Recent
Amana Easy Reach AFD2535DE Bottom Freezer Refrigerator Questions & Answers
I can't get the bypass cap off to replace the
I just got my whirlpool fridge and I'm having the exact same problem! The blue cap appears stuck and I'm afraid I'll break it if I force it with a tool. Please post a solution if you get one - I'll do the same. Thanks.
My refrigerator smells like urine
The smell is coming from the back of my refrigerator and it has been noticeable for about a month. It is the worst when the motor is running. The inside is fine; no smell. Any ideas?
My amana bottom freezer was
freon is oderless,the gas has no smell to it,what was wrong with the fridge?having sealed system work isn't cheap,was this a new unit?but the gas has no oder
My Amana ABC2037DPS Refridgertor is not keeping
Most likely the coils under the refrigerator need cleaning. Unplug the refrigerator and remove the front, vented cover below the door. With a vacuum cleaner and crevice tool clean the coils off. It may also help the clean off the door gasket and apply a very thin coat of Vaseline. (Don't forget to clean the refrigerator edge that makes contact with the gasket.)
Ic6 ice maker
Some models like yours came with a defrost control board and others came
with a defrost timer. They should be found inside the fresh food
compartment and behind the temperature control panel. You will need to
inspect and let me know which you have. Unplug first. If the control
board looks or does not look burned it could be bad. The timer can be
turned clockwise until compressor stops and should remain stopped for about 25 minutes. and then turn itself back on. If these
look good then we need to remove the rear panel inside the freezer and
test the defrost element with one wire disconnected to check for
continuity. Just to be sure the element has not burned out. The defrost
thermostat is connected to the defrost element and will have open
contacts inside it above 50 degrees.
Clicking, buzzing, compressor too hot, thawed out
Sounds like the compressor is in thermal overload. Let it cool down completely and meter the starting amperage on start to run. The compressor could be seized or it's windings could be shorted to ground (checking the resistance between the windings terminals on the compressor while unplugged will determine this.).
WHERE IS THE DEFROST TIMER LOCATED ON ARB1905CW
The defrost timer is located in the main control board or on the bottom back side of the fridge. It will be a little black box. But my guess is the control blade which means the board will need to be replaced
Good luvk
