20 Most Recent GE XL1800 1100 Watts Microwave Oven Questions & Answers
2answers
The microwave unexpectedly turns off at random
You could try a new plug just in case, next the fuse inside or thermal cut out could be @ fault, could be the cable transformer end as it enters the micro.....
6/30/2019 10:01:52 AM • GE XL1800 1100... • Answered on Jun 30, 2019
GE Spacemaker XL 1800 Micro - " Turns itself off after 2 sec. "
It looks like a component is short-circuited and then it acts to protect. Call a service.
11/14/2017 8:51:08 AM • GE XL1800 1100... • Answered on Nov 14, 2017
I have the GE Profile
ITS MAY BE HIGH VOLTAGE SIDE PROBLEM. DIODE OR CAPACITOR
9/18/2017 4:03:18 AM • GE XL1800 1100... • Answered on Sep 18, 2017
My Microwave continues to run unless door is open.
The high pitch sound to me may be coming from the speaker on the main circuit board. Try to unplug for a few minutes, reset clock time and then try again. If same issue, may need new PC board. When you say Microwave continues to run are you meaning the Turntable is turning and the fan running?? Or is it just timing down. Almost never does it actually keep heating. On GE units I mostly find bad door switches will cause a back feed and make the tray turn and the cooling fan for the mag to run. To see if that is the problem You have to look at the door switches behind the front panel on the left side and see if any of them have any browned connections on the terminals where they push ontl the back of the switch. That will cause the fan and turntable toi run, but wouldnt cause a high pitch squeal. These companies use switches wtih small 3/16 terminals that dont give a good enough grab on the switch, they get loose and hot and make the switch go bad. I replace that switch with a switch with 1/4 inch terminals and runa short section of Hi temp wite to it and it wont go bad again. Just cheaply made!! Also I guess the squeal could come from the turntable motor area. So By fixing the switch problem it could fix your squeal. With nothing else running you may be able to hear motor and coupling noise you couldnt hear before.
8/18/2017 5:15:16 PM • GE XL1800 1100... • Answered on Aug 18, 2017
2answers
GE Model # JVM7195SFSS microwave.
Check the internal ceramic fuse on the circuit board. Sometimes one section will work while another won't. I'm not sure if this model has a rear mounted thermal fuse, but the models with the inline thermal fuse will cause a similar issue.
6/22/2016 8:19:08 AM • GE XL1800 1100... • Answered on Jun 22, 2016
How do I turn off demo mode?
I had a hard time to find this fix. you unplug it for 1min and then plug it back in and press and hold the power and 0 keys for 30sec. That is it http://forum.appliancepartspros.com/microwave-repair/33654-stuck-demo-mode-no-heat.html#ixzz48TqseDoE
5/12/2016 9:45:42 PM • GE XL1800 1100... • Answered on May 12, 2016
GE Spacemaker XL1800 vent fan doesn't pull air from beneath
On the exhaust system (top of unit) there is a small metal 'damper' that is most likely stuck shut. If that is all clear then you have a problem in the duct work of the home.
7/27/2015 12:47:03 PM • GE XL1800 1100... • Answered on Jul 27, 2015
My ge is Microwave beeping and says keypad short may need service
PCM/Smart board (comes with the keypad), If it is less that 30 days beyound the 12 month warranty call GE and ask for a "good will concession" ... 1800-GECARES
2/11/2015 10:08:30 PM • GE XL1800 1100... • Answered on Feb 11, 2015
My GE stainless steel 1100 watt microwave starts beeping out of the blue and the display panel shuts off and when I open the door it resets itself and then starts to beep when I close the door again.
Try removing the power cord for about a minute, push all the touch pad 'buttons' and then plug it back in. If this doesn't work it sounds like you may have a bad door interlock switch or a bad PCM .. Good luck !
2/11/2015 9:55:10 PM • GE XL1800 1100... • Answered on Feb 11, 2015
Doen't heat food
More information will be needed to solve this issue. Does the keypad work? What about the interior light or the turntable? Check the internal fuse, and the door interlock switches.
7/4/2014 2:53:12 PM • GE XL1800 1100... • Answered on Jul 04, 2014
Somebody exploded an egg in Kitchenaid Microwave combo oven, and circuitboard went bad. Power but no heat. Coincidence?
The circuit board is in a separate section so the motherboard can't come into contact with the exploded egg. Was any liquid cleaning solution sprayed inside to clean up the mess? There might be some crevices where cleaning solution spray could work its way into the circuit board section since it's very close by. Always use a damp cloth instead of saturating the oven with cleaner.
6/2/2014 2:21:09 PM • GE XL1800 1100... • Answered on Jun 02, 2014
2answers
GE XL 1800 Fan Won't shut off
Assuming you've not had recent trouble with the cooktop lights, then I would suspect your "hood thermostat" is defective.
It should read normally open, and when it fails it will short.
If you or someone you know decide to work on it, we have *critical* safety, disassembly, and troubleshooting info at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
You can usually find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
If you've recently had trouble with your cooktop lights, then you probably have a damaged control panel (circuit board) which we repair for only $39.95 postpaid.
If that seems to be the issue, or if you'd like more detailed help, please feel free to contact us via our listing here on FixYa: http://tinyurl.com/yzjozk
We're happy to help and we appreciate your thoughtful rating of our answer.
5/2/2014 3:34:25 PM • GE XL1800 1100... • Answered on May 02, 2014
0answers
Demo mode
Be the first to answer 4/18/2014 4:07:25 PM • GE XL1800 1100... • Posted on Apr 18, 2014Be the first to answer
Microwave gets really hot on inside, especially the right wall, but the food will not get hot at all
it seems that the right wall inside of the microwave is absorbing most of the microwave energy. If the panels are replaceable then you might want to consider having them replaced but it probably wouldn't be worth it. Maybe buying a new microwave will save you a lot of expense and grief. Good luck
4/10/2014 3:57:12 AM • GE XL1800 1100... • Answered on Apr 10, 2014
How to find fuse
Elaine, it will be inside the outer housing of the microwave. Un-plug the power cord and then take out the screws holding the outer cover on, some may be a special "torx" screw which will take a special tool to remove them. The fuse will be right near where the power cord enters the back of the unit. Usually goes to a small circuit board and the black wire typically connects to one end of the clip that the fuse snaps into. Hope this helps.
4/3/2014 5:19:31 PM • GE XL1800 1100... • Answered on Apr 03, 2014
GE XL1800 1100 Watts Microwave Oven Logo
326 questions posted
Top GE Microwave Ovens Experts
vince
NOEL
NOEL
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
View Most Popular
GE Microwave Ovens
  • GE Microwave Ovens
Most Popular Question
microwave gets really hot inside
  • Microwave Ovens
