20 Most Recent Danby 22 in. DDW396 Free-standing Dishwasher Questions & Answers
2answers
Danby Countertop Dishwasher Spray Arm not turning
now ya need to find out how the food got by the screen and into the pump motor to get shot into the spray arm
6/19/2022 6:09:54 AM • Danby 22 in.... • Answered on Jun 19, 2022
2answers
Water filling then emptying again right away
Take the cover off, as you face unit on right side follow the vacum hose to two presure switches. Tap on them lightly with a the handle of screw drive. fix my unit three months ago still working. The problem is the presure switch.
6/7/2021 7:49:25 AM • Danby 22 in.... • Answered on Jun 07, 2021
2answers
My danby countertop dishwasher won't drain
the problem has not been resolved. does not drain.
5/17/2020 3:52:08 AM • Danby 22 in.... • Answered on May 17, 2020
6answers
Danby DDW396W won't drain
If you remove the cover, you will discover that there are two motors inside. The larger one on the right runs to fill the machine and spray the water during washing. The smaller one on the left drains it. Oiling this motor, or manually actuating it by spinning the wheel between cycles may solve your problem.
2/24/2019 9:11:36 PM • Danby 22 in.... • Answered on Feb 24, 2019
2answers
Danby DDW396W-2
I have had a similar problem numerous times, a couple of which required manoeuvreing it into a place I could work on it, and a laborious removal of the covers. Each time, up until this current incident, the solution that worked, at least temporarily, was quite simple. The recurrent problem was at least consistent: every 6-8 months I would find that the pump would work but the spray arm was not moving. The solutions always seemed to be something different: once all I needed to do was to prime the pump, other times it seemed like calcium and lime build-up was clogging up the parts so a little C.L.R. got me on my way.
This most current incident was more baffling, as my standard solutions did not work. However, I think I finally got to the root of the problem.
Look inside the dish compartment, to the right, near the top. There are two little nubby holes. Their function is to allow air to enter/exit either the spray arm pump tubing or the water filling tubing. Remove the one zillion screws from the cover to access the innards. Pull off the tubing and unscrew the washer (it will be tight due to the sealant on it). Upon inspection, I found that the air hole for the spray arm pump was clogged with food residue. A tiny screwdriver will clear things out nicely - you should be able to see through it. If you clear it out a little but, but still can't see through it, then I presume you're just going to have the same problem back again.
It is important that this be clear so that the water can displace the air while filling is occurring and allow for good suction. Actually, it looked like a manufacturing flaw - there was still some residual plastic from the original molding on the inside, and food was getting caught on it.
Good luck.
10/31/2014 1:15:43 AM • Danby 22 in.... • Answered on Oct 31, 2014
0answers
0answers
0answers
Danby countertop dishwasher DDW396W pump size???????????
Best place for Danby parts is Sears Parts department online. Type in your model number DDW396W. They have diagrams and assessable and parts for just about everything you need.
http://www.searspartsdirect.com/partsdirect/getModel!retrieve.pd?modelNumber=DDW396W&pop=flush
Just click on the sub components area that you need!
-Dustin
10/11/2012 1:50:43 PM • Danby 22 in.... • Answered on Oct 11, 2012
Dishwasher has a smell
have you tried using a dishwasher cleaner? i know electrosal makes one...just follow the instructions and they work pretty well. also you could check and make sure there is no food caught in the drain trap...that could cause a smell too...
5/6/2012 3:38:38 AM • Danby 22 in.... • Answered on May 06, 2012
0answers
Spray arm problems
MAKE SURE YOU ARE GETTING ENOUGH WATER INTO THE
DISHWASHER. THEN CHECK FOR A RESTRICTED PUMP
INLET PORT LOCATED UNDER THE METAL STRAINER
ON THE RIGHT SIDE. IT IS A SMALL HOLE WITH A PLASTIC
GRID MOLDED INTO THE WELL, APPROX. 1 INCH IN DIAMETER.BE SURE THERE ISN'T ANYTHING PLUGGING UP
THE HOLES IN THE PLASTIC GRID.
7/13/2011 2:39:43 AM • Danby 22 in.... • Answered on Jul 13, 2011
0answers
2answers
Will not drain the water out.Between cycles or at the end
This might be to simple but if the pump seems to run then check the tubes for any way that it might be blocked bends, blocks, ect. If the pump is not running, check out Sears Parts Online. They have just about every part for Danby. Put in your model number and choose a sub component with what you need.
Good Luck!
-Dustin
1/24/2011 3:06:56 AM • Danby 22 in.... • Answered on Jan 24, 2011
2answers
My dishwasher fills with water then doesnt switch
sound like the timer is not advancing properly
10/16/2010 2:50:14 AM • Danby 22 in.... • Answered on Oct 16, 2010
Danby 22 in. DDW396 Free-standing Dishwasher Logo
Popular Tags
60 questions posted
Top Danby Dishwashers Experts
Mike Cairns
Mike Cairns
ADMIN Andrew
ADMIN Andrew
Are you a Danby Dishwasher Expert? Answer questions, earn points and help others
View Most Popular
Danby Dishwashers
  • Danby Dishwashers
Most Popular Question
danby ddw399w dishwasher drainage spin
  • Dishwashers
