20 Most Recent
Sony BRAVIA KDL-V32XBR1 32 in. LCD HDTV Questions & Answers
My Sony Bravia 32" flat screen tv will not stay on
Fault at its main digital board.
Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Pull up older posts.
https://electronicshelponline.blogspot.com/
In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Before going further; try a hard reset first. If it does not help you, replace the main digital board. There are two methods to reset TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight is better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; visit the site linked here.
No picture, vertical colored lines
I have never heard of a warm-up problem on a digital television. Unlike the old CRT TVs and monitors, digital panels don't have to warm up. I would go with the TV repair persons assessment that you've got a bad panel.
Bravia Color
why can't you adjust the color? What do you mean
Sony lcd klv32s530A negative picture colour green
hi friend,
I would suggest sending it back to the manufacturer with a complaint. They will probably send you a coupon so you can get another TV free. It worked when I did that.
hope this solves ur problem
regards
sivaranjini
