20 Most Recent
Fujitsu Siemens LifeBook N6110 Notebook Questions & Answers
Need to remove a keyboard
Remove the Keyboard on a Fujitsu Laptop
Fujitsu makes several series of laptops,
with multiple models in each series. Some Fujitsu keyboards are
attached with only a few tabs and can be removed with little hassle, but
other laptops require more steps to remove the keyboards.
Difficulty:Moderate
Instructions
Things You'll Need
- Flat, hard piece of plastic
- 1Prepare a clean and organized workspace.
2Turn the laptop off. Turn the laptop over and slide the battery switch to pop out the battery.
3Turn the laptop back over and
remove the keyboard bezel, the thin piece of plastic directly above the
keyboard, by prying it up with a small flat object, such as a hard piece
of thin plastic.
4Lift up the keyboard and flip it over to rest on the mouse/palm rest.
5Disconnect the motherboard
connection by carefully pulling down on the two tabs on either side of
the connector. After the connection is unlocked, gently pull the cable
to disconnect it.
6Remove the keyboard.
Tips & Warnings
- Discharge any static electricity by touching a metallic surface before working with your computer, to avoid damaging sensitive circuits.
I forgot my bios password.
If you don't know the system(BIOS) password for your System, forgotten it, or its not accepting it again, then you might have to reset your CMOS.
Which means you will have to unscrew your system, remove all cables supplying power to the board, locate the CMOS battery and remove it for a few seconds, then replace it and screw your system back.
This will reset your system's CMOS back to its Factory default settings.
(If you cant unscrew your PC yourself, you can just get a good technician to do it for you instead.)
Hope it helps.
Missing ntldr file
Best option is to reload the OS if you need to get the best perrformance from yourr PC. Use a good antivirus the next time your OS is loaded..
Skype
hi, first check in sound recorder if ur microphone is working, also check the sound card properties it the microphone in enabled,let me know..
Bios password
You have to locate the cmos battery on the motherboard and remove it for a few minutes, and possibly need to locate the clear cmos terminals and short the cmos terminal pins, but the name of the pins you need to locaye depends on the motherboard, normally JBAT1 terminal or CLRCMOS or CLRCLK or similair.
How to format a install windows xp3 on FUJITSU SIEMENS
backup your data first in any external source. insert bootable cd of xp and boot from it. follow the instruction and finish the installation after that install required drivers and apps.
in starting you need to select boot from cd., can be select-able from bios and also by pressing f12.
My power button is not working, is their any way to start the nootebook making a power shortcut?
If the laptop was opened up, (ALL power removed -> AC adapter and battery; PLUS -> anti-static precautions taken!), and the laptop has a power on switch, (under the power on button), that plugs into the motherboard; you can unplug the switch, and touch the motherboard contacts to try to turn the laptop on. (Sorry about the run-on sentence) Jump a wire or similar, across the contacts, and see if the laptop turns on. Could try to be more specific, and detailed, if you had listed more info about the Fujitsu Lifebook. Such as it's Series number and Model Number. Example: Fujitsu Lifebook E8210. In this example E is the Series number, and 8210 is the Model Number. Post back in a Comment.
Regards,
joecoolvette
How do I get into bios
As soon as the Fujitsu logo appears on the screen, press the F2 key. If this doesn't work, please post the specific family and model of your Fujitsu Siemens LifeBook PC.
Thanks,
Roger
How to download recovery disc
Recovery disc comes from the manufacturer and looks for the serial number of your computer. You would have to buy a recovery disc from the said manufacturer or just go buy a new operating system CD
