20 Most Recent
Andis Agc Super 2-speed Clipper International 220-volt Dog Grooming Clippers Questions & Answers
My clipper smoked and now it wont run at all
Sounds like your motor went out. You might as well buy new clippers for the price to fix them. One thing that causes that is when you spray your coolant to not hold your clippers blade up. Keep them blade down. The coolant can run into your clippers and burn them up. You only want to use grease inside your clippers.
Moser max 45 won't cut
Most common cause will be the blades have gone dull and should be
sharpened or replaced. Check that the 2 screws on the blade latch assy
are tight where it screws onto the front housing, blade off to check
them. 3rd thing to check is for excessive wear in the lever that drives the blades, if it is worn replace it.
Why is clipper over heating
Either your blades need cleaning and oiling or it's possibly a faulty armature without testing the clippers and part mentioned with a multimeter it's hard to say.
Armature
Blade not staying on tight
If you can pull the blade away from the clipper without pressing the blade release button then either the hook on the Latch is broken (which will mean all blades have the same problem) or the blade socket on the blade may need adjustment or replacement. Please view the part in question
Latch
Is CBD Pet Products Safe for My Pet?
As a caring owner of a pet, it is right that you are concerned about whether
CBD Pet Products will be safe for your furry family member. The thing to remember here is that CBD in its pure state can be tolerated well by animals and are safe. This has been stated by the World Health Organization's 2017 report. However, you should remember that the market for CBD Products is not regulated. So, there are chances that the CBD gummies and other products can contain ingredients that are listed on the label including THC, which can be toxic to pets. All you have to do to ensure the safety of your pet is to get the product from a trustworthy source.
How to get rid of racoons
to get racoons rid follow these steps
- Cover and secure your trash cans so raccoons cannot access the contents.
- Remove any possible food sources like cat or dog food, compost piles, and trash.
- Treat your lawn to remove grubs.
- Block access to hiding places like under a deck or entrances to the crawl space and attic.
Animals symbolic meanings
Cats symbolise elegance, curiosity, courage and adaptability. Dog - Typifies loyalty, kinship, bravery, perseverance, and happiness and also conveys protection and reliability. Penguin - These aquatic birds symbolise devotion, loyalty, unity, and lasting love.
What is fever dog is
A dog's normal body temperature ranges from 101° to 102.5° Fahrenheit, which is significantly higher than humans whose body temperature ranges from 97.6° to 99.6° F. A temperature of more than 103° F is considered a dog fever. When temperatures reach 106° F, serious and fatal complications can occur.
What can i give my dog for diarrhea whilst nursing pups
Fast your dog for 24 hours. Only water is permitted. After the 24 hour fast, begin feeding a combination of boiled white meat chicken (with all the skin and fat removed and the water poured off) and boiled long grain white rice. Boiled ground beef with fat removed and water poured off is also a good alternative.
