20 Most Recent
Wahl Whal Stable Pro Pet Animal Clippers 8800 Extras Horse Dog Questions & Answers
How to reassemble blades on wahl stable pro 8800
Do you have more parts in your hand than 2x screws and 2x blade parts? If no then pop the small cutter blade onto the plastic blade drive with the drive engaged into the diamond shaped hole in the cutter blade. Make sure you put the cutter blade on with the teeth facing forwards and the correct way up. The top side (goes towards clipper) is pretty much flat except where teeth taper. Next lubricate the small cutter where it is going to touch the large comb blade when you fit it. Now put the comb blade on and fit the 2 screws. Line up the blades & tighten the screws.
How to get rid of racoons
to get racoons rid follow these steps
- Cover and secure your trash cans so raccoons cannot access the contents.
- Remove any possible food sources like cat or dog food, compost piles, and trash.
- Treat your lawn to remove grubs.
- Block access to hiding places like under a deck or entrances to the crawl space and attic.
Animals symbolic meanings
Cats symbolise elegance, curiosity, courage and adaptability. Dog - Typifies loyalty, kinship, bravery, perseverance, and happiness and also conveys protection and reliability. Penguin - These aquatic birds symbolise devotion, loyalty, unity, and lasting love.
What is fever dog is
A dog's normal body temperature ranges from 101° to 102.5° Fahrenheit, which is significantly higher than humans whose body temperature ranges from 97.6° to 99.6° F. A temperature of more than 103° F is considered a dog fever. When temperatures reach 106° F, serious and fatal complications can occur.
What can i give my dog for diarrhea whilst nursing pups
Fast your dog for 24 hours. Only water is permitted. After the 24 hour fast, begin feeding a combination of boiled white meat chicken (with all the skin and fat removed and the water poured off) and boiled long grain white rice. Boiled ground beef with fat removed and water poured off is also a good alternative.
Why is my Staffordshire scratching all the time and chewing at her feet
Could be a food allergy; don't buy cheap treats or food from supermarkets, they have colouring and toxic chemicals in them. Go to a propper independant pet store.
There is also an issue with the floor cleaning products, always use a non chemical cleanser like Savlon floor cleaner. No harsh chemicals in it.
Check for grass mites.
