20 Most Recent
Sharp EL-2196BL Calculator Questions & Answers
Sharp EL-2196BL
Make sure that it is installed properly ... going under not OVER. Does the paper feed when the paper feed key is depressed ??
1. Lift the paper holder up.
2. Fold the leading edge of the paper roll 3 to 5 cm. (Do not fold it slantwise.)
3. Insert the paper roll from the left side of the paper holder and make sure the paper
roll is set in the proper direction (with the paper feeding from the bottom).
4. Insert the leading edge of the paper into the opening directly behind the print
mechanism.
5. Press the paper feed key and feed the paper under the edge of the paper cutter.
Paper/tape jam
Get a pair of scissor and cut through the tape. IF it is rapped up too tight where you can't get a pair of scissor through it, then get an exacto knife or razor blade to cut the paper. Just remember not to press too hard so you don't cut through the rubber roller beneath it.
After cutting the paper, then press the paper advance and start taking the pieces of paper out.
Good luck.
If you still have problems, feel free to repost again.
Have a good day.
Mac =)
