20 Most Recent
Naxa 13.3" NTD-1352 12V HD LED AC/DC Widescreen ATSC Digital TV w/DVD Questions & Answers
Need to remove base on nAXA Model NTD-1354
I needed to do this as well. The round part comes off but the stem does not come out of the TV. I don't mind taking things apart so I removed the screws on the back all around the frame. There are two screws right above all the hookups that you don't have to remove. After removing the screws, carefully separate the two halves. They snap togetther together on the middle of the sides. It takes a little effort to unsnap them I just kept running my fingernails up and down the seam until it popped apart. The screen half come off and is connected with some wires so don't pull it to far apart. At this point you can access the two silver screws that hold the stem in place. Remove the screws and the stem can be removed. Now snap the two halves back together (being careful not to pinch any wires) and re-apply the screws. I saved all the parts for the base in case I needed to put it back together. Last note, opening anything like this may void any warranty.
Where is the Google on the Matertech?
It appears that there could be miscommunication. As of my previous update in January 2022, Matertech doesn't seem to be a commonly known term or corporation. On the other hand, if you're talking about "Google," it's a well-known worldwide technological corporation that specializes in internet-related services and goods, such as search engines, cloud computing, online advertising technologies, software, and hardware.
Google's official website or an internet search utilizing one of the search engines like Google itself are usually the easiest ways to get information about Google. If "Matertech" relates to a particular thing or idea, further information could be helpful in order to provide a more precise answer.
How do I download Showmax on my Sinotec STL-55G50 smart tv
- Turn on your Smart TV: Ensure your Sinotec TV is powered on and connected to the internet.
- Navigate to the App Store: Look for an app store or marketplace on your TV's home screen. It might be called something like "App Store," "Google Play Store," or "Smart Hub."
- Search for Showmax: Use the search function within the app store to search for the Showmax app. You can usually find this by typing "Showmax" into the search bar using your TV remote.
- Select and Install the Showmax App: Once you've located the Showmax app in the app store search results, select it, and then choose the option to install or download it to your TV.
- Open the Showmax App: After the installation is complete, navigate back to your TV's home screen and locate the Showmax app icon. Select it to open the app.
- Sign In or Sign Up: If you already have a Showmax account, sign in using your credentials. If not, you may need to sign up for a Showmax account using your email address and creating a password.
- Start Watching: Once you're signed in, you should be able to start browsing and watching content on Showmax.
- Hope this helps
