20 Most Recent
Epson Stylus Photo R2400 InkJet Printer Questions & Answers
R2400 has been unused for
try this. use rubbing alcohol on a lint free towel and wipe the head clean. This will not affect the head as it will dry fast. I had this happen before because the ink dry and harden if it still does not work than you might need to repeat this process a few times.
Nozzle cleaning
Use old cartridge and put isopropyl alcohol with a mixtue of 3 parts alcohol to 1 part water into cartritge with a syringe . Go thrugh cleaning cycle 4-5 times and let sit with newspaper under printer for any leaks. Run cleaning cycle several times until you get printer to run clear on sheet of paper. Reinstall cartridge with new ink. Lot of work but have done this and it will work. Make sure you clean out old cartridge with alcohol first over sink and fill each color chamber up with mixture before installing cleaning cartridge. Also eBay offers some of these cleaning cartridges.
Epson Stylus Photo R2400 does not start up.
That sounds like the main control board is faulty.
Use Epson.Co.(your country) to find some local service agents, describe those symptoms to them and compare their answers.
Paper feed jams on right hand side after I pulled bits of an A4 that came out ripped
Bruno:
You did not get all the pieces of that A4 paper out of the paper path. There is still a small shard of paper in the right side of the paper feed area. Use a flashlight to look carefully in the paper feed area and gently use tweezers to remove the piece of paper. If you pulled the sheet of A4 paper backwards out of the feed area, you may have dislodged the paper feed sensor (a small plastic finger that sticks down in the paper path to tell the printer that the paper has passed.) Be careful with the tweezers... if you break that sensor, there is no fixing it.
Epson R2400 does not display all the paper types
It depends on which Black cartridge you have installed. For Glossy Photo papers the Photo Black (PK) needs to be in the printer. For all other papers to appear then you need to change it to the Matt Black (MK) cartridge.
Paper doesn't feed properly R2400
You may have a paper jam. A small piece of paper in the rollers will cause that. Open printer and look for any paper in between the rollers, pull it out.
Epson r2400 won't feed paper
I had the same problem, then found these instructions for cleaning the feed roller:
http://www.museofineart.com/files/RollerCleaningProcedureRev2.pdf
I used the paper towel method and it's working fine now with no issues.
