20 Most Recent
Konica Minolta Bizhub 363 Copier / Printer / Scanner Questions & Answers
How to reset c2557
Might want to have the developer replaced and drum/cleaning blade normally done all together, then run the TCR procedure/Developer Charge, and make sure the counters where cleared. Did you recently replace the drum and the developer if so did you clear the counters for the drum and developer, FIRST? IF not then the copier thinks the new drum and new developer are old. The copier works on the counters that is how it knows it got a new drum and developer. Get new developer and a new drum and have it installed correctly. Ensure Drum Dry is run first, Counters are clear before the unit is yanked out of the machine, then you remove the image unit/drum unit replace the developer/drum and cleaning blade. (DO NOT USE A VACUUM CLEANER WHEN REPLACING THE DEVELOPER static electricity can destroy the sensor located below the developer unit. Then reinstall and RUN TCR Developer Charge. Make sure the fax line and Ethernet cable is removed can't print anything until the TCR is run. Or you will start all over again with new developer and a new drum. Btw, I’m available to help over the phone in case u need at
https://www.6ya.com/expert/normanj_7893313f0751935f
Erroe code 0202
open the 1st draw check for paper behind the draw THEN REMOVE THE PAPER ON THE LEFT SIDE OF THE DRAW NOT A STORAGE AREA ITS FOR 11 x 17 PAPER!!!!! if the code comes back burn out the motor or worse damage the control board and the motor get a tech out to look at it. Btw, I’m available to help over the phone in case u need at
Toner error
if replaced the cartridge ,The problem is something else.but u refilling the toner, maybe the chip set on the cartridge is gone.
HOW TO RESOLVE CODE C-2221 KONICA MINOLTA BIZHUB C5500
1.The terminal for the first transfer pressure/release sensor is not connected properly.
Reconnect the terminal.
2.Failed PS15 (p/n 08AA 8551 2).
Test photosensor, PS15, in the I/O State Confirmation Mode, 48-0HIGH = home position or LOW = Other than home position by activating M19 (p/n 08AA
8003 0) transfer pressure/release motor, 48-0, 48-1, 48-2, or 48-3. Replace thephotosensor or motor as needed.
3. Possiblefailed Transfer/Pressure Release motor (M19).
Check the operation of the motor(p/n 08AA 8003 0) in the I/O State confirmation mode for proper operation with code 48-0; this should rotate the motor
constantly. Replace motorif needed.
Also check for possibleopen ICP fuses, ICP3 (5V DC)and ICP4 (24V DC) on the AC drive board (p/n A03U H520 01). Replace the drive board as necessary.
SPECIAL NOTE : Solution contribution by KMBT (Japan) and Freddie Burnham, Production Print/SSD
