20 Most Recent HP DeskJet 1280 InkJet Printer Questions & Answers
Instal hp dekjet 1280 with
Wireless printers may face an installation problem with Windows 7 operating system. For example, Toshiba laptop is compatible with this operating system yet it may require a driver download for executing a print command on wireless printer. To combat this challenge, users are advised to delete and re-install the printer. If the problem persists assign the wireless printer to a fixed address through a router instead of the Dynamic Host Configuration Protocol (DHCP). Accessing the wireless printer from a laptop with Windows 7 operating system can be a challenge. Often, it may display the printer to be offline. To resolve the issue, users must cancel printing jobs immediately and delete offline printers from the Printers option in the Control Panel. Visit the Printer properties and access the Ports tab, delete the printer that displays the offline status and appears as Client Side Rendering Provider. Delete the Port button and click apply. Restart the PC. Now re-install the wireless printer by visiting the Control panel, opening Printers and clicking option add a printer. Now select add a local printer, followed by selecting the option "Use an existing port", LPT1: (Printer Port). Install the printer driver offered by Windows 7. In the next window leave the Set as a default printer box unchecked and re-name the printer. Click Next. Upon successful installation, the operating system will display the message "You've successfully added printer name"
2/2/2022 8:09:48 PM • HP DeskJet 1280... • Answered on Feb 02, 2022
6answers
Hp deskjet 1280 driver printer for windows 7
download hp deskjet 1280 for win 7 32 bit http://www.wupload.com/file/3797628/HPDJ1280_for_win_7.exe
7/22/2021 4:27:00 AM • HP DeskJet 1280... • Answered on Jul 22, 2021
2answers
How to check the page count on it?
HP Deskjet report printing instructions:
10/9/2019 9:07:18 PM • HP DeskJet 1280... • Answered on Oct 09, 2019
My deskjet 1280 simply Won't turn on.
Hi
A couple of times this has happened to me and it is to do with the access port at the back of the printer ie it has a lock - unlock symbol on it and a circular handle. Make sure that this is firmly in the locked position. Note that it may seem to be in the locked position but often there is a little bit more it will go ... though dont force it so that it breaks ... try unlocking and firmly locking a couple of times, each time testing the on button. Like I said this has worked for me before
Regards
Mark
8/17/2018 5:52:05 PM • HP DeskJet 1280... • Answered on Aug 17, 2018
6answers
Printer Problem in HP-1280 Printer
printer tidak dapat proses setelah refill tinta. led blinking terus, bagaimana solusinya setelah merefill tinta.
3/27/2018 9:16:01 AM • HP DeskJet 1280... • Answered on Mar 27, 2018
Hello sir, Windows 7 AutoCAD
if everything else works ok except AutoCAD then the problem is not the printer, it is a broken data connection between AutoCAD & the printer. Sometimes all it takes is to unplug & replug the cable, or restart the pc with printer already connected.
5/3/2017 6:06:40 AM • HP DeskJet 1280... • Answered on May 03, 2017
2answers
Re: low ink light on hp 1280
if there are the #45 - you should try this
http://www.refillinstructions.com/HP/HP-reset.htm
Don't forget to vote
11/4/2016 11:46:29 AM • HP DeskJet 1280... • Answered on Nov 04, 2016
Why is the red light blinking in my HP Deskjet and what can i do?
HP has excellent Customer Support, on the Internet and by phone. You might start here, which is a page specifically for your product: https://h20565.www2.hp.com/portal/site/hpsc/public/psi/manualsResults?sp4ts.oid=439162&ac.admitted=1472900155638.1123376534.492883150
9/3/2016 10:58:23 AM • HP DeskJet 1280... • Answered on Sep 03, 2016
What will i do to my hp deskjet 1280 when the red light is blinking
does the user manual help ? http://support.hp.com/us-en/product/HP-Deskjet-1280-Printer-series/439162/model/439174/manuals/
9/3/2016 10:07:10 AM • HP DeskJet 1280... • Answered on Sep 03, 2016
HOW TO CHECK PAGE COUNT ON IT?
Here is link for manual: HP Deskjet 1280 Printer series
11/29/2015 2:53:03 AM • HP DeskJet 1280... • Answered on Nov 29, 2015
How to reset HP DeskJet 1280 InkJet, it's can't
REMOVE THE REAR COVER BY TWISTING THE HANDLE AND THEN RE INSTALL IT
9/9/2015 7:31:19 PM • HP DeskJet 1280... • Answered on Sep 09, 2015
2answers
Its stop printing and the LED power light green
ts stop printing and the LED power light green and orange at the center blink, like there is a paper jam.
9/3/2015 5:53:20 PM • HP DeskJet 1280... • Answered on Sep 03, 2015
Why doesn't my laptop recognize it?
There may fault in USB cable or USB or dot framework might not have been installed on our Laptop
8/1/2015 2:44:11 PM • HP DeskJet 1280... • Answered on Aug 01, 2015
3 light blink
If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. http://electronicshelponline.blogspot.com/ Search the site by type in the brand name to your device, in the "Search box at the top right of the display window".
7/22/2015 4:50:18 AM • HP DeskJet 1280... • Answered on Jul 22, 2015
3 light continous blink
Paper jam.. most likely a very small piece caught in the roller.
7/22/2015 4:44:05 AM • HP DeskJet 1280... • Answered on Jul 22, 2015
How i solve the blank print on a3 paper on autocad
It seems you are using a print server to connect the printer 1280 to your LAN. Uninstall the printer software and printer server driver. Connect the print server to the network and first re-install the print server driver. Then connect the printer to the print server and install the printer software. Refer user manual for assistance. Bot the print server and printer software should be compatible with your operating system.
1/8/2015 2:23:07 AM • HP DeskJet 1280... • Answered on Jan 08, 2015
Manual service
printer hp deskjet 1280 doesnt catch paper
11/5/2014 9:08:51 AM • HP DeskJet 1280... • Answered on Nov 05, 2014
2answers
Am hving hp deskjet 1280
hi
I think you must check some things like:
- usb cable is good cable and work correctly.
-your computer USB ports works correctly.
-the power is connected to printer and its work and its leds plink.
-you choose the write driver.
6/30/2014 6:09:14 PM • HP DeskJet 1280... • Answered on Jun 30, 2014
HP DeskJet 1280 InkJet Printer Logo
398 questions posted
k24674
Grand Canyon Tech
Grand Canyon Tech
View Most Popular
DeskJet HP
  • DeskJet HP
Most Popular Question
printer problem in hp 1280 printer
  • Office Equipment & Supplies
