20 Most Recent HP Deskjet 6940 InkJet Printer Questions & Answers
Hp deskjet 6940 paper jam
This past Saturday we just had a similiar problem on our church HP printer. Different number than yours, but most likely the same solution. It jammed when the last person used it, so they removed the crinkled paper. Or so they thought - there was a piece maybe 1-1/2" triangular shape stuck on top. I liked to never found it, I looked even with a flashlight 4 times before I caught just a hint of white way up there. If that is not it, there could be a door you have not opened. Most of them open top, back, front. Ours also opens on the side. The back opens in two places. Occasionally there can be a piece of paper you can only see from one door.
7/25/2021 11:43:00 AM • HP Deskjet 6940... • Answered on Jul 25, 2021
2answers
HP Deskjet 6940 not printing after replacing ink cartridge
My HP Deskjet 6940 is not printing. The color (left) low ink light is dark and the black (right) low ink light is flashing. I replaced the black ink cartridge with a new one but the low ink light continues to flash. No tears/rips in the circuit strip and all the copper leads appear to be connected
2/1/2018 9:45:43 PM • HP Deskjet 6940... • Answered on Feb 01, 2018
2answers
HP Product Assistant disk
go online to Hp webpage, download the driver and install it. it will fix your problem.
Regards I’m happy to help further over the phone at https://www.6ya.com/expert/mustafa_06f84c65ab5cc745
2/1/2018 9:38:28 PM • HP Deskjet 6940... • Answered on Feb 01, 2018
Hp 6940 is not printing black
Hi It sounds like a good chance the black has blocked it does not take much just things like leaving the cartridge out for a bit or it can also take a bit to get a new cartridge working. I would recommend you try to do a head clean it uses a lot of ink doing this but sometimes there is no choice. In settings you should be able to do only black option. Regards Craig
2/1/2018 7:31:30 AM • HP Deskjet 6940... • Answered on Feb 01, 2018
HP Deskjet 6940 Series Printer:
Try a original cart if it does work it will need a printhead.
11/25/2017 10:39:25 PM • HP Deskjet 6940... • Answered on Nov 25, 2017
My HP 6940 will not print 4x6 photo paper in upper
Go to the settings menu and select paper handling and set the paper to 4x6.
10/2/2017 5:54:39 PM • HP Deskjet 6940... • Answered on Oct 02, 2017
HP6940 won't print red
I can only say that the preamble is with the ink cartridge. Just happens that red is one of the first to get clogged. Happened to me on the 95 ink cartridge. If you need further help, I’m available over the phone at https://www.6ya.com/expert/alex_22751bbefa74c3d0
6/17/2017 4:58:33 AM • HP Deskjet 6940... • Answered on Jun 17, 2017
2answers
My printer says its offline how do I reconnect?
hi
just folow the step
Step 1
Open the Start menu and click on the "Printers and Faxes" icon. This will open a window with a list of the printers currently set up on your computer.
· Step 2
Double-click on the icon of the printer you want to change to online. A pop-up window detailing all current print jobs will open.
· Step 3
Go to Printer in the menu bar of the pop-up window and uncheck "Use Printer Offline." This action will change the printer from offline to online.
Mac Instructions · Step 1
Open System Preferences by clicking on the icon in the Dock.
· Step 2
Go to the Print & Fax control panel under the Hardware category.
· Step 3
Select the printer you want to take online from the list on the left side of the screen. Then click on the "Open Print Queue" button.
· Step 4
Click on the "Resume Printer" button at the top of the queue window to change the printer from offline to online.
4/27/2017 6:43:37 AM • HP Deskjet 6940... • Answered on Apr 27, 2017
How can I print color photos in black and white?
you can click it for 10 seconds and it will show you to print it and other stuff and when it shows the whole screen click color and ther you go
5/11/2016 1:39:38 AM • HP Deskjet 6940... • Answered on May 11, 2016
Please, I need the service manual
User's Manual here, from HP's website http://www.hp.com/ctg/Manual/c00591689.pdf
7/13/2015 5:08:53 PM • HP Deskjet 6940... • Answered on Jul 13, 2015
I can't find 'toolbox' on HP Deskjet 6940 printer
If you are running Windows 7 I believe it has been disabled. There are some work arounds but I'm not sure.
5/13/2015 6:12:41 AM • HP Deskjet 6940... • Answered on May 13, 2015
0answers
HP Deskjet 6940 InkJet Printer, white lines across
do a clean - goto printer properties - should see tools there you can choose to do a clean or deepclean also try a head alignment on the maintenance section
7/15/2014 1:13:48 PM • HP Deskjet 6940... • Answered on Jul 15, 2014
HP Deskjet 6940 InkJet Printer Logo
350 questions posted
k24674
Grand Canyon Tech
Grand Canyon Tech
View Most Popular
DeskJet HP
  • DeskJet HP
Most Popular Question
not print off internet
  • Office Equipment & Supplies
